Siebel Wireless Administration Guide For Financial Services > Using Siebel Wireless > Personalizing Your Wireless Device >
Main Menu Layout
The Main Menu Layout form lets you personalize the main menu that is displayed when you access a Siebel Wireless application using an Openwave browser. You choose the links you want to appear on the main menu and in what order they should appear. To personalize your main menu, use the following fields:
 Published: 18 April 2003
