Siebel Object Interfaces Reference > Web Client Automation Server Quick Reference > Object Interfaces Reference >
Siebel HTML Application Methods for the Web Client Automation Server
Table 147 describes a summary of Siebel HTML application methods you can use with the Web Client Automation Server. It does not include object interface methods that Siebel CRM does not call directly from an application instance. For information about methods that Siebel CRM calls with the InvokeMethod method on the application, see LoadObjects Method for an Application.
Table 147. Summary of Siebel HTML Application Methods for the Web Client Automation Server
Method
Description
Format
GetLastErrCode Method for an Application
Returns the error code for the error that Siebel CRM logged most recently.
Dim siebelApp As SiebelHTMLApplication
Dim iErr as Long
iErr = siebelApp.GetLastErrCode
GetLastErrText Method for an Application
Returns the text message for the error that Siebel CRM logged most recently.
Dim sText as String
sText = siebelApp.GetLastErrText
GetService Method for an Application
Locates a business service. If this business service is not already running, then Siebel CRM starts it.
Dim svc As SiebelService
Set svc = siebelApp.GetService(ServiceName as String)
Name Method for an Application
Returns the name of the Siebel application.
Dim name as String
name = siebelApp.Name
NewPropertySet Method for an Application
Creates a new property set.
Dim propSet as SiebelPropertySet
Set propSet = siebelApp.NewPropertySet
Siebel Object Interfaces Reference Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
