Siebel Product Administration Guide > Product and Promotion Eligibility and Compatibility > Eligibility and Compatibility Workflow Reference >
Check Eligibility & Compatibility - Default Workflow
This workflow is responsible for checking the eligibility and compatibility of a quote or order line item.
This workflow is shown in Figure 18.
Figure 18. Check Eligibility & Compatibility - Default Workflow
Workflow Description. This workflow does the following:
  • Project Asset Key?. Determines whether the Projected Asset Key is present.
  • Query Projected Asset. If the Projected Asset Key is present, searches for the asset.
  • Name Change. Calls the Conditional Action Transform for the Business Service Row Set Transformation Toolkit.
  • Product E & C. Calls the Product Eligibility & Compatibility - Default workflow.
  • Store Instance Information. Stores instance information that will be used in the Delete RowSet Data step.
  • Multiple Popup Workflow. Calls the Compatibility Multiple Popup Workflow.
  • Delete RowSet?. Determines whether any Line Items in the Row Set have been marked for deletion.
  • Delete RowSet Data. Deletes any Line Items that are marked for deletion.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
