Siebel Product Administration Guide > Siebel Configurator Version 6.x, 7.0 and 7.5 >
Designing Rules and Logical Expressions in Version 6.x and 7.x
The version 6.x Basic Rule Designer, Logic Designer, and Advanced Rules Designer have been replaced by the Rule Designer in version 7.0 and 7.5. The Rule Designer provides a series of natural-language rule templates that you can use to create rules of any complexity. You can also create and save your own rule templates.
The logical operators in the version 6.x Logic Designer are provided in picklists associated with the rule templates.
A special rule template is provided to enter rules in Siebel Configurator Rule Language (renamed Rule Assembly Language in version 7.0 and 7.5). The operators and syntax in version 6.x Siebel Configurator Rule Language are supported in version 7.0 and 7.5. Table 51 maps version 6.x features to 7.0 and 7.5 for designing rules.
Table 51. Designing Rules in the Rule Designer
Version 6.x
Version 7.0 and 7.5
Comment
Create rule in Basic Rule Designer
Create rule using rule template in Rule Designer.
Rules can be created with or without conditions.
Create expressions in Logic Designer
Use logical operators associated with rule templates in Rule Designer.
Create rule in Advanced Rules Designer
Enter rule into special template in Rule Designer.
version 6.x operators and syntax are supported in version 7.0 and 7.5.
Category-to-product rules
Class-to-product rules.
The product class must be part of a relationship.
Category-to-category rules
Class-to-class rules.
The product classes must part of relationships.
Product-to-product rules
Product-to-product rules.
None.
Copy and delete rules
Copy and delete rules.
Includes rules that are logical expressions.
Activate and deactivate rules
Activate and deactivate rules.
Application generates rule explanations
Application generates rule explanations or you can write explanations.
Rule Summary report
Rule Summary report.
None.
Enforce resource total by placing check mark in resource record
Write rules to prevent resources from having negative values.
None.
Syntax checker for Siebel Configurator Rule Language
Syntax checking is provided when building rules using the Assisted Advanced Rule template and all other rule templates.
Siebel Configurator Rule Language is called Rule Assembly Language in version 7.0 and 7.5.
Siebel Product Administration Guide Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
