Siebel Product Administration Guide > Siebel Configurator Scripts > About Managing Siebel Configurator Scripts >
Deleting Siebel Configurator Scripts
After deleting a script, test the customizable product in validation mode to verify that the product works correctly. To delete a script
- Navigate to the Administration - Product screen.
- Select and lock the desired product or product class.
- Navigate to the Scripts view for the Work Space version.
- In the Scripts list, select the script you want to delete.
- In the Scripts list, click Delete.
- Open the Scripts view list menu and click Validate.
This starts a configuration session. Verify that the customizable product functions correctly.
