Siebel Database Upgrade Guide for DB2 for z/OS > Reviewing the Siebel Upgrade Log Files > About the Siebel Upgrade Log FilesThe Upgrade Wizard writes logs that provide detailed information on the upgrade processes and they also list all errors. The Upgrade Wizard writes the logs for a process to the following directory by default: Windows:
where The
The output and state directories are automatically archived on subsequent runs of a process that completes successfully. (The names of subsequent log directories are appended with NOTE: You can select a different log directory from the Log Output Directory screen on the Database Configuration Wizard. About the State Log FileEach upgrade process consists of a series of steps, each of which must complete successfully. If the Upgrade Wizard cannot complete a step, it marks the step as incomplete in the state.log file and exits. The state.log file is located in You must correct the error and then run the Upgrade Wizard again. When you rerun the Upgrade Wizard, it refers to the state log and resumes at the incomplete step that contained the error. About Process Log FilesYou can identify errors you encounter during an upgrade by reviewing the log file named UpgWiz.log (Windows) or srvrupgwiz1.log (UNIX) in the The name of the log file increments for subsequent log files that are created if the Siebel Upgrade Wizard encounters a problem and you run the Siebel Upgrade Wizard again. Review the end of the log file for details about the latest failure. If the step that failed was not a native SQL step (which would be listed in the log file), then it occurred as part of an external utility. You can review the relevant log file, which is identified by the / How to Determine if the Upgrade Process Completed SuccessfullyIf the status of all the steps in the state.log is Complete, the upgrade process completed successfully. If the status of any step is Incomplete, the upgrade process did not complete successfully. You must identify the error and correct it before resuming the upgrade. NOTE: In some cases, the Upgrade Wizard can complete a step even though the step contains unacceptable errors. You must verify that all steps do not contain unacceptable errors, even those with a status of Complete. Use the following process to identify errors:
If you have any questions regarding how to resolve errors, create a service request (SR) on My Oracle Support. You can log service requests by accessing My Oracle Support (Service Request tab), or by using your existing phone support numbers to contact Oracle Global Customer Support. Log Files That Can Be IgnoredIf the upgrade completed successfully, there are several log files that you can safely ignore:
CAUTION: UNIX Only: The log file |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
