Siebel Database Upgrade Guide for DB2 for z/OS > How the Siebel Database Upgrade Works > About Unicode SupportPrevious releases of Siebel Business Applications supported ASCII- and EBCDIC-based coded character set IDs (CCSIDs) on DB2 for z/OS. Since Siebel CRM 8.0, Unicode is also supported on DB2 for z/OS version 8 and later releases. For a list of supported languages and code pages, see Siebel System Requirements and Supported Platforms on Oracle Technology Network. You can migrate your Siebel database from an EBCDIC or ASCII code page to a Unicode encoding system but this process is not part of the standard Siebel CRM 8.1 upgrade procedure. A separate migration procedure for migrating to Unicode is performed on the DB2 host after you have upgraded to Siebel CRM 8.1. For information on migrating to Unicode, see Implementing Siebel Business Applications on DB2 for z/OS. NOTE: If you have migrated your Siebel CRM 8.0 z/OS database to Unicode format, you cannot upgrade to Siebel CRM version 8.1. Unicode upgrades are not supported on the z/OS platform in Siebel CRM 8.1. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
