Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > About Creating a Schedule for the UpgradeDevelop a plan for your upgrade based on the objectives and constraints for your deployment. If you are migrating multiple languages from a prior version, plan extra time for the repository merge process. The expected merge time can increase with the number of languages in the repository. You also might have to plan for additional installation-related tasks. The following procedures can reduce the time required for your upgrade:
Do not start a new development effort until after the new version has been rolled out. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
