Siebel Database Upgrade Guide for DB2 for z/OS > Planning a Siebel Database Upgrade > Staging and Target Database PlanningWhen scheduling your upgrade, be aware that the target database schema must not be changed after the staging DDL is produced. If target database schema changes are applied before the upgrade is completed, you must recreate the staging database and generate the upgrade files again. When planning your upgrade, keep in mind the following:
DB2 DSNZPARM Settings For the Target DatabaseFor Siebel Business Applications to run correctly and efficiently, the DSNZPARM parameters for your target database must be set correctly. For a list of the required and recommended DSNZPARM parameter settings for DB2 for z/OS when using Siebel Business Applications, see Implementing Siebel Business Applications on DB2 for z/OS. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
