Siebel Database Upgrade Guide for DB2 for z/OS > Performing Postupgrade Tasks on the Target Database > Transferring the Development Environment Upgrade Output Files to the z/OS HostEnvironments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. The development upgrade upgphys process generates the following files, which are used to complete the development upgrade:
Transfer these files to the z/OS host using the following procedure. To transfer the development environment upgrade output files to the z/OS host
NOTE: If the development and production upgrades are run on different midtier computers, then you must copy the files to be transferred to the z/OS host to the production midtier computer before running the ftp_syncdd.bat file. About the Dedup FilesThe dedup files and dedup_prod.jcl files generated by the upgphys process are similar to the files that you generate during the Prepare for Production Upgrade process, which is run for upgrades from Siebel CRM version 7.5.3 before the production environment upgrade is started. Since both processes use the same information when generating these files, you can use the dedup files created by either the upgphys process or the Prepare for Production Upgrade process. |
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
