Siebel Database Upgrade Guide for DB2 for z/OS > Creating the Siebel Staging Database > Transferring the Staging DDL to the z/OS HostWhen the Upgrade Wizard stops at Pause # 0, you must transfer the SQL and JCL templates and other staging DDL that has been generated on the midtier to the z/OS host where they can be executed. To do this, perform the following procedure. To transfer the staging DDL to the z/OS host
Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2012, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
