Using Siebel Tools > Using Siebel Tools > Using Editors in Siebel Tools >
Specifying the Web Template Editor
This task is a step in Roadmap for Setting Up and Using Siebel Tool.
The Web template editor is an application that is external to Siebel Tools that allows you to edit a Web template. For example, if you right-click a Web template in the Web template explorer, then Siebel Tools opens the editor that you specify and displays this Web template in the editor. You can specify the external application that Siebel Tools opens.
To specify the editor for Web template files
  1. In Siebel Tools, choose the View menu, and then click Options.
  2. In the Development Tools Options dialog box, click the Web Template Editor tab.
  3. In the Folder full path field, enter the full path to where your Web template files reside.
  4. Under External Web template editor, do the following:
    1. Use the Browse button in the Executable full path field to navigate to and choose the executable for the external Web editor.
    2. In the Optional parameters field, enter the parameters that Siebel Tools must send to the executable when it opens the external editor.
  5. Click OK.
Using Siebel Tools Copyright © 2013, Oracle and/or its affiliates. All rights reserved. Legal Notices.
