Enter a code that identifies which partner is due to receive the listed item. Values are:
C: Company. Your company expects to receive product from the partner.
P: Partner. Your partner expects to receive product from the company.
Enter a value that identifies where an item on the agreement is delivered. This required field must match these Destination Type codes:
If the destination type is AB, the destination must be an address book number in the Address Book Master table (F0101).
If the destination type is CC, the destination must be a business unit in the Business Unit Master table (F0006).
If the destination type is *A, the destination must be *ANY.
