This chapter contains the following topics:
Several programs enable you review information about your bulk stock. You can review bulk product transactions, monthly tank stock statuses, meter readings, tank readings, and inventory balances for tanks containing commingled or custody stock.
This section provides an overview of product transaction review and discusses how to: review product transactions.
Set processing options for Bulk Product Transaction Inquiry (P415201).
Review product transactions.
You can review the history of all transactions for a specific bulk product or product and location. These transactions might be the result of an intra-depot stock movement, a sale (which posts after the customer sales update process), or a purchase receipt.
You can access Bulk Product Transaction Inquiry from the Bulk Stock Management menu or the Intra-Depot Stock Movements menu.
To work with meter readings, you can access the Work With Multi-Meter Readings form directly from the Bulk Stock Reconciliations menu.
Form Name | FormID | Navigation | Usage |
Work with Bulk Transaction Inquiry | W415201A | Bulk Stock Management (G41501), Bulk Product Transaction Inquiry | Review product transactions. |
Processing options enable you to specify the default processing for programs and reports.
Specify a document type.
Specify the version of the Load & Delivery Ledger Inquiry (P49511) program. If you leave this processing option blank, the system uses ZJDE0001.
Access the Work With Bulk Transaction Inquiry form.
Figure 11-1 Work With Bulk Transaction Inquiry form
This section provides an overview of reviewing monthly tank stock status and discusses how to:
Set processing options for Monthly Tank Stock Status (P415205).
Review monthly tank stock status.
Use the Monthly Tank Stock Status form to review a monthly summary of all transactions that affect tank stocks. You can review only transactions that have been operationally reconciled. You can run the Monthly Tank Stock Movements report from the Work with Monthly Tank Stock Status form.
Work with Monthly Tank Stock Status | W415205A | Bulk Stock Management (G41501), Monthly Tank Stock Status | Review monthly tank stock status. |
Enter document types for incomings and outgoings.
The system code is a user-defined code (UDC) from table 98/SY that identifies a system. Values include:
01: Address Book
03B: Accounts Receivable
04: Accounts Payable
09: General Accounting
11: Multicurrency
Record Type identifies the table that contains UDCs. The table is also referred to as a UDC type.
Specify the version the system uses for Bulk Product Transaction Inquiry (P415201). If you leave this field empty, the system uses ZJDE0001.
Enter a reconciliation range for From and To that identifies the current status in the reconciliation process.
Note: Set up Reconciliation Status - Current UDCs sequentially in the same order as the process flow. The same codes are used for Reconciliation Status - Next. |
Access the Work with Monthly Tank Stock Status form.
Figure 11-2 Work with Monthly Tank Stock Status form
This section provides an overview of reviewing meter readings and discusses how to:
Set processing options for Meter Readings (P415105).
Review meter readings.
You can review meter readings for a given product or meter for a specific time period. You can view records of reconciled stock, unreconciled stock, or both, depending on the status codes set in the processing options. You cannot delete meter readings from the Work With Multi-Meter Readings form. The system stores records in the Multi-Meter Readings table (F41515).
Work With Multi-Meter Readings | W415105A | Bulk Stock Reconciliations (G41502), Meter Readings | Review meter readings. |
Specify the Reconciliation Status Code that indicates that the transaction has been throughput reconciled. Records with this status (and any status greater than the one entered) will be protected from changes.
Identifies the current status in the reconciliation process. Entries in this field are UDCs.
Access the Work With Multi-Meter Readings form.
Figure 11-3 Work With Multi-Meter Readings form
Enter the date of the new closing reading.
Enter a number that identifies the meter.
This section provides an overview of reviewing location segment inquiry and discusses how to review location segment inquiry.
Use the Location Segment Inquiry form to review the inventory balances for tanks containing commingled or custody stock.
Balances for some tanks by owner might be negative. A negative balance occurs when only one tank is current and all product is withdrawn from that tank, regardless of ownership.
Location Segment Inquiry | W4100142B | Inventory Inquiries (G41112), Location Segment Inquiry | Review location segment inquiry. |
Access the Location Segment Inquiry form.
Figure 11-4 Location Segment Inquiry form
This section provides an overview of reviewing tank readings and discusses how to:
Set processing options for Tank Dip Readings (P415106).
Review tank readings.
Use the Tank Dip Readings program (P415106) to view all of the physical tank dip readings as of a specific date and time. The system displays information from the Tank Master File table (F41500) and the Bulk Product Transaction File table (F41511). If no dip reading is available as of the specified date, the system retrieves the data from the Default Tank Information table (F41508).
Work with Tank Dip Readings | W415106D | Bulk Stock Reconciliations (G41502), Tank Dip Readings | Review tank readings. |
Specify the status code beyond which a dip reading cannot be changed. This code indicates the point at which a reading has been operationally reconciled.
