Skip Headers
JD Edwards EnterpriseOne Applications Demand Flow Manufacturing Implementation Guide
Release 9.1
Part Number E15099-01
Go to Documentation Home
Home
Go to Book List
Book List
Go to Table of Contents
Contents
Go to Index
Index
Go to Feedback page
Contact Us
Go to previous page
Previous
Go to next page
Next
PDF · Mobi · ePub
Glossary
Line Design Name
Enter a name to identify the line design. You can create multiple versions of a line design for one line, but you have to designate one version as active. Based on the line design you create, you can plan and sequence production on the line, and determine the resource requirements.
Line Name
You have to set up a line to be able to create a line design and to plan production. If you integrate Oracle JD Edwards EnterpriseOne Demand Flow Manufacturing with Oracle JD Edwards EnterpriseOne Manufacturing, you have to define the line as a work center of type 2 using the Work Center Revision program (P3006).
Process Map Name
Enter the name of the process map from which you retrieve the process information for line design. The process map lists all products and the processes required to produce the products that you want to include in the line design, as well as the resources and resource times required to produce them.
Scenario Name
You have to create scenarios as the context within which to create a line design. All data that you set up in JD Edwards EnterpriseOne Demand Flow Manufacturing are specific to a scenario. You can only designate one scenario as active.
