This chapter contains the following topics:
Section 1.1, "JD Edwards EnterpriseOne Demand Flow Manufacturing Overview"
Section 1.2, "JD Edwards EnterpriseOne Demand Flow Manufacturing Integrations"
Section 1.3, "JD Edwards EnterpriseOne Demand Flow Manufacturing Implementation"
JD Edwards EnterpriseOne Demand Flow Manufacturing enables a manufacturing company to design its production facility to meet the requirements of demand-driven manufacturing. In a demand-driven environment, a manufacturer has to be able to build any model at any time based on existing demand. To support this goal, JD Edwards EnterpriseOne Demand Flow Manufacturing enables you to:
Design a manufacturing line based on the processes required to build the products in a mixed model family.
Calculate the throughput for the line based on demand at capacity.
Calculate kanban sizes based on the line design to ensure a smooth supply of component parts.
Calculate labor and machine resource requirements based on the work content of each process, to meet daily demand and to support demand at capacity production levels.
Plan and sequence production.
You can integrate JD Edwards EnterpriseOne Demand Flow Manufacturing with JD Edwards EnterpriseOne Manufacturing. In this case you import base data, such as item information, bills of material, resource information and sales orders into JD Edwards EnterpriseOne Demand Flow Manufacturing. If JD Edwards EnterpriseOne Demand Flow Manufacturing is not integrated with JD Edwards EnterpriseOne Manufacturing, the system provides programs to set up these data within JD Edwards EnterpriseOne Demand Flow Manufacturing.
The JD Edwards EnterpriseOne Demand Flow Manufacturing system integrates with these JD Edwards EnterpriseOne systems from Oracle:
JD Edwards EnterpriseOne Inventory Management
JD Edwards EnterpriseOne Accounts Payable
JD Edwards EnterpriseOne Accounts Receivable
JD Edwards EnterpriseOne Human Resources Management
JD Edwards EnterpriseOne Product Data Management
JD Edwards EnterpriseOne Shop Floor Management
JD Edwards EnterpriseOne Product Costing
JD Edwards EnterpriseOne Manufacturing Accounting
JD Edwards EnterpriseOne Sales Order Management
We discuss integration considerations in the implementation chapters in this implementation guide.
The JD Edwards EnterpriseOne The Inventory Management system creates item branch and location records.
The JD Edwards EnterpriseOne Accounts Payable system creates supplier records.
The JD Edwards EnterpriseOne Accounts Receivable system creates customer records.
The JD Edwards EnterpriseOne Human Resources Management system creates employee records.
The JD Edwards EnterpriseOne Product Data Management system creates bills of materials, work centers and routings.
The JD Edwards EnterpriseOne Shop Floor Management system creates orderless item completions.
The JD Edwards EnterpriseOne Product Costing system creates and maintains cost information for items.
The JD Edwards EnterpriseOne Manufacturing Accounting system creates accounting transactions for orderless shop floor transactions.
This section provides an overview of the steps that are required to implement the JD Edwards EnterpriseOne Demand Flow Manufacturing system.
In the planning phase of your implementation, take advantage of all JD Edwards EnterpriseOne sources of information including the installation guides and troubleshooting information.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne Demand Flow Manufacturing, use the EnterpriseOne and World Change Assistant. EnterpriseOne and World Change Assistant, a Java-based tool, reduces the time required to search and download ESUs by 75 percent or more and enables you to install multiple ESUs at one time.
See JD Edwards EnterpriseOne Tools Software Updates Guide.
This table lists the suggested global implementation steps for the JD Edwards EnterpriseOne Demand Flow Manufacturing system:
Set up global user-defined codes.
See "Working With USer Defined Codes" in the JD Edwards EnterpriseOne Tools System Administration Guide.
Set up companies, fiscal date patterns, and business units.
Set up next numbers.
Enter address book records.
Set up inventory information such as branch/plant constants, default locations and printers, manufacturing and distribution AAIs, and document types.
Set up the shop floor calendar.
Set up manufacturing constants.
This table lists the suggested application-specific implementation steps for JD Edwards EnterpriseOne Demand Flow Manufacturing. The required implementation steps vary depending on whether you are implementing JD Edwards EnterpriseOne Demand Flow Manufacturing with integration to JD Edwards EnterpriseOne Manufacturing or without integration.
If you integrate JD Edwards EnterpriseOne Demand Flow Manufacturing with other JD Edwards EnterpriseOne applications, you use these applications to set up some of the required data. If you use JD Edwards EnterpriseOne Demand Flow Manufacturing without integration, you use the base data programs in JD Edwards EnterpriseOne Demand Flow Manufacturing to set up these data.
Set up scenarios.
Set up a default user scenario.
Set up branch information, standard unit of measure conversion, items, bills of material, customers, suppliers and employees.
See Setting Up Base Data for Demand Flow Manufacturing.
Note: Use this implementation step if you use JD Edwards EnterpriseOne Demand Flow Manufacturing without integrations. |
Set up items.
Set up locations.
Set up customers.
Set up suppliers.
Set up employees.
Set up bills of material.
Set up work centers and routings.
Set up data movement configurations.
See Integrating Demand Flow Manufacturing with Other JD Edwards EnterpriseOne Applications.
Set up mixed model families.
Set up processes.
Set up paths.
Set up product synchronizations.
Set up volume design.
Set up standard tasks.
Set up standard sequence of events.
Set up sequence of events.
Set up cells.
Set up process maps.
Set up lines.
Set up a line design.
Set up an operational definition.
Set up kanban constants.
Set up kanban location master records.
Set up kanban pull chains.
Set up a resource design.
Set up resource design effectivity dates.
