This chapter contains the following topics:
This section provides an overview of job master records for PGCA contracts, lists a prerequisite, and discusses how to set up job master records for PGCA contracts.
After you set up the contract and its corresponding invoice and funding levels, you can then set up the job master records and attach the appropriate contract numbers for the funding levels.
Each job that is a government-direct job must track the funding level associated with it, and the structure of the contract attached to the funding level for the job must be enforced. The system uses the business unit type assigned to the job master record to determine whether to track the funding level. If the job master record contains a business unit type that you defined in the Service Billing Constants program (P48091) as a PGCA job, then the system requires you to enter a contract number in the Funding Level field. The system then populates the corresponding numbers in the Invoice Level and Contract Level fields.
Before setting up job master records for PGCA, define the business unit types that are used for PGCA.
Access the Job Master Revisions form.
Figure 7-1 Job Master Revisions form: Revise Single Job tab
Select a valid business unit type. If you select a business unit type that is defined in the Service Constants program (P48091) as a PGCA job type, then you must enter a contract number in the Funding Level field.
Enter the contract number of the funding level with which this job is associated. After you enter the contract number of the funding level, the system populates the Invoice Level and Contract Level fields with the corresponding numbers.
The system populates this field based on the value in the Allocation Level field in the contract for the funding level.
Select a category from user-defined code (UDC) table 48S/BC to identify the types of expenses that are charged to accounts in this job. The system uses the value in this field when you perform actual rate calculation.
Select this option to indicate that a job is for expenses that are not allowed by the U.S. federal government according to the Federal Acquisitions Regulation (FAR).
Select this option to indicate that a job is for adjustment entries only.
Use these fields to enter additional information about the job. The system uses the Category Code 12 field to obtain the pool grouping code, so you cannot use this field for any other purpose.
Note: The system prints these fields in the Job Master List report (R51006P). |
Enter dates that fall within the period of performance (POP) dates in the funding level for the contract. The system generates an error if the dates that you enter do not fall within the POP date range.
If you leave these fields blank, the system populates them with the POP dates from the funding level contract.
