This chapter contains the following topics:
Section 5.1, "Understanding Maintaining Blocks and Harvests"
Section 5.8, "Maintaining Harvests Using Speed Harvest Update"
You often revise and update existing information through a growing period. After you add block and harvest records, you can revise information on individual or multiple records. To maintain block and harvests you can:
Edit and copy block and harvest records.
Initiate a block.
Use speed update programs for specific fields on multiple records.
Perform mass updates on attributes you define to be changed.
Push revisions on a block to associated harvests.
Create new harvests by rolling closed or current harvest to future harvest records.
This diagram illustrates the maintenance tasks that you can perform on block and harvest records:
Figure 5-1 Block and Harvest Maintenance Tasks
Before you complete the tasks in this chapter:
Create block records.
Create harvest records.
This section provides an overview, and discusses how to maintain block records.
For single block records you can perform the following maintenance tasks:
Edit block records.
Copy block records.
Inactivate a block.
You can revise values for a single block record by accessing the Add/Edit Grower Block form.
You can copy values from existing block or harvest records to another record to minimize redundant data entry. When you copy a record, the system copies most of the values from the original record enabling you to revise the values on the new record. For example, you could use the copy function to set up a model block that you use as a template. Because blocks can look very similar, setting up model blocks enables you to copy the values from the model to another block and then update that block with specific information.
The JD Edwards EnterpriseOne Grower Management system enables you to inactivate a block record. However, all of the harvests associated with the block must a be at Closed or Terminated status.
Access the Add/Edit Grower Block form.
This section provides an overview of speed block maintenance and discusses how to:
Set processing options for Speed Block Update (P40G020).
Maintain blocks using speed block update.
Several ways are available to update data on a block. When a simple change to one block is required, you can access the Add/Edit Grower Block form. However, when changes are required across multiple blocks, you can use the Speed Block Update Block program (P40G020) or the Mass Update program (R40G0200).
Using the Speed Block Update program, you can display specific block records and update information on the individual lines that require changes. Updates you can perform include the following values:
Block status.
Block address number.
Growing area, appellation, region, and district.
Variety code.
Maturity calculation program name.
Supplier number.
Default price.
Target and current quality.
Grower attributes and grower dates.
Item number.
Material type.
Harvest pattern.
Use these processing options to control whether the system allows these fields to be updated.
These processing options control whether users can update certain fields.
Specify whether the system allows users to update the dimension unit of measure. Values are:
Blank: Allow updates.
1: Do not allow updates.
Specify whether the system allows users to update the pricing unit of measure. Values are:
Specify whether the system allows users to update the container type and quantity per load. The container type and quantity per load are related fields. Values are:
Access the Speed Block Update form.
This section provides an overview of mass updates on blocks and discusses how to:
Create a block record update profile.
Set processing options for Mass Update - Block (R40G0200).
Run the Mass Update - Block program.
Use the Mass Update - Block program to update block attributes. This is a two-step process. First, you must create a block record update profile. This profile specifies the fields that the system updates and the new values. The second step is to launch the report. The system updates the fields on all records that are identified in the program's data selection.
If the report finds an error, it does not process the record. You should run this report in proof mode and then in final mode.
Access the Add/Edit Grower Block Update Profiles form. Select the check box for each field or attribute you are changing, and enter the new value.
Figure 5-4 Add/Edit Grower Block Update Profiles form
Enter a unique description of a mass update profile for the grower block.
The system assigns a profile ID.
To make changes to the block header information, select the check box for these fields and enter the new value:
Update Farm Name
Update Block Name
Update Block Type
Update Grower Composition Code
Update Grower Representative
Update Blend Representative
Update Contract Representative
Update Supplier Number
Update Growing Area
Update Appellation
Update Region
Update District
Update Variety Code
Update Current Quality
Update Target Quality
Update Block Address Number
Update Material Type
Update Planned Estimate
Select the Attributes 1 tab.
Figure 5-5 Add/Edit Grower Block Update Profiles form: Attributes 1 tab
To make changes to the attributes 1 information, select the check box for these fields and enter the new value:
Update Irrigation Type
Update Irrigation Volume
Update Pruning Method
Update Soil Type
Update Clone
Update Root Stock
Update Grower Attribute 01
Update Grower Numeric 01
Update Row Spacing
Update Plant Spacing
Update Number of Plants
Update Planted Area
Update Gross Area
Update Dimension A
Update Dimension B
Update Dimension UOM
Update Elevation
Update Extraction Rate
Update Planted Date
Select the Attributes 2 tab.
To make changes to the attributes 2 information, select the check box for these fields and enter the new value:
Update Grower Attribute 02 thru 15.
Update Grower Checkbox 01 thru 05.
Update Grower Date 01 thru 08.
Update Grower Numeric 02 thru 05.
Select the Defaults tab.
To make changes to the default information, select the check box for these fields and enter the new value:
Update Crush Site
Update Produced Site
Update Default Price
Update Pricing UOM
Update Container Type
Update Quantity Per Load
Update Maturity Program Name
Select the Additional tab.
To make changes to the additional information, select the check box for these fields and enter the new value:
Update Alternate Block Name.
Update Parcel Number 1 thru 3.
Update Governmental ID 1 thru 4.
Update Operator ID.
Update Site ID Number.
Update Parcel Number 1 Area.
Update Parcel Number 2 Area.
Update Parcel Number 3 Area.
Use these processing options to control how the system processes data and to define default versions.
These processing options control whether the system runs in proof or final mode and specifies which profile to use.
Specify whether the system runs in proof or final mode. Values are:
Blank: Run in proof mode.
1: Run in final mode.
Enter the update profile ID that determines which block values you want to update.
Enter the version of Add/Update Block (P40G02) for the system to use.
Select Grower Management Periodic Processing (G40G121), Block Record Mass Update.
When you run the Mass Update - Block program, the system updates the fields on the block record based on the fields and values that you specified in the update profile from the processing options. The system does not update the associated harvest attributes for the changed block records.
This section provides an overview of pushing grower block changes to harvests and discusses how to push grower block changes to harvests.
When you make changes to certain fields on a grower block record, you can push the changes to the related current and future harvests. Pushing changes to other related harvests enables you to keep certain information about the harvests in-sync between the various related harvests.
To push harvest information, you identify an existing grower block record in the Search for Grower Blocks form of the Block Entry program (P40WG02). When you click the Edit link for the block record that includes the information to push to other harvests, the system displays the Add/Edit Grower Block form. Click the Update Harvest option and then click the Save and Close button to access the Push Grower Block to Harvest form.
The Push Grower Block to Harvest form includes three options that you can select to push information to harvests. You can select one or multiple options. The options are:
Push Attributes
When you select this option, the system copies attributes, such as the block code, region, and variety, from the block record to the selected harvest records.
Push EUR
When you select this option, the system deletes the current EURs for the selected harvest records and then copies the block EURs to the selected harvest records.
Push Estimates
When you select this option, the system updates the existing planned and current estimates of the selected harvest records with the planned estimates of the block record. If the Create Purchase Orders processing option is set to 1 in the Grower Harvest Maintenance program (P40G03), the system creates purchase orders when push estimates change.
If you change the maturity calculation program name on the block and then push this change to selected harvests, the system updates the program name, but does not recalculate the maturity date for the harvest. To recalculate the maturity date, click the Refresh button on the Add/Edit Grower Harvest form. On the Push Grower to Harvest form, you can replace the previous maturity calculation program name only with the new program name from the block. You cannot change the maturity calculation for individual harvest records on this form.
This diagram shows the grower block push process:
Access the Search for Grower Blocks form.
Figure 5-7 Push Grower Block to Harvest form
Enter identifying information in the header area, and then click Find.
The system displays the block records that meet the search criteria that you entered.
Click the Edit link for the block record for which you want to push information to harvest records.
The system displays the Add/Edit Grower Block form.
On the Add/Edit Grower Block form, make any desired changes to the block record, and then:
Select the Update Harvest check box.
Click the Save and Close button.
The system displays the Push Grower Block to Harvest form.
Perform one of these actions:
Select the Push to Harvest check box for each harvest record to update.
Click the Select All button to select all harvest records.
Select one or more of the Push options:
Push Attributes
The system updates the selected harvest records with the attribute values of the block.
Push EUR
The system overwrites existing values for the selected harvests with the EUR information from the block.
Push Estimates
The system overwrites existing values for the selected harvests with the estimate information from the block.
If a confirmation window appears, click OK to confirm your updates.
The system displays a confirmation window if you select Push EUR, or Push Estimates.
This section provides an overview, and discusses forms used to maintain harvest records.
For single harvest records you can perform the following maintenance tasks:
Edit harvest records.
Copy harvest records.
Reset harvest status.
You can revise values for a single harvest record by accessing the Add/Edit Grower Harvest form.
You can copy values from existing harvest records to another record to minimize redundant data entry. When you copy a record, the system copies most of the values from the original record enabling you to revise the values on the new record. The harvest period that you enter must be set up in the Harvest Period Pattern.
Access the Add/Edit Grower Harvest form.
These processing options control default processing for the Calculate Maturity Dates program (R40G50).
This processing option controls how the program processes data.
Specify the maturity date calculation program with the custom calculation the system uses to calculate maturity dates. If you leave this processing option blank, the system uses the maturity date calculation program that you associated with the selected harvests.
This processing option controls the program versions that the system uses.
Specify the version of the Grower Harvest Maintenance program that the Calculate Maturity Dates program calls when calculating maturity dates. If you leave this processing option blank, the system uses the default version.
Select Periodic Processing (G40G121), Calculate Maturity Dates.
Run the Calculate Maturity Dates program (R40G50) to calculate maturity dates for the crops of selected harvests. When you run the calculation, the system updates the Calculated Maturity Date and the Date Last Updated field for the selected grower harvests.
If you specify a maturity date calculation program in the processing options, the system uses this program. Otherwise, the system uses the maturity date calculation program that you entered for the harvest.
The calculation updates the maturity date only if the harvest status is Current or Future. You can run this program only in final mode.
Running the program also generates a report that prints errors and warning messages that are generated when attempting to recalculate crop maturity dates.
This section provides an overview of maintaining harvests using speed harvest update and discusses how to:
Set processing options for Speed Harvest Update (P40G030).
Maintain harvests using Speed Harvest Update.
You can quickly update data on a harvest in several ways. When a simple change to one harvest is required, you can use the harvest workbench. However, when changes are required across multiple harvests, you can use the Speed Harvest Update program (P40G030). Using this program, you can display specific harvest records and update information on the individual lines requiring changes.
Use these processing options to control whether the system allows these fields to be updated. Access the processing options through interactive versions.
These processing options control whether certain fields are displayed and whether users can update certain fields.
Specify whether the system allows updates to the harvest status. Values are:
Specify whether the system allows updates to the calculated maturity date. Values are:
Specify whether the system allows updates to the container type and quantity per load. Values are:
Specify whether the system displays the harvest period effective dates. Values are:
Blank: Display the harvest period effective dates.
1: Do not display the harvest period effective dates.
Specify whether the system displays the default price. Values are:
Blank: Display the harvest default price.
1: Do not display the harvest default price.
Access the Speed Harvest Update form.
For each harvest, update the fields that require revisions, for example, harvest status, current and target quality, maturity calculation program name, planned maturity date, and composition information. You can revise the value in the Maturity Calculation Program Name field only if the harvest status is Current or Future.
If the Harvest Workbench program (P40G032) uses a version of the Grower Harvest Maintenance program (P40G03), which is set to create a purchase order, the system creates a purchase order if you revise the harvest end date.
This section provides an overview of performing mass updates on harvests and discusses how to:
Create a harvest record update profile.
Set processing options for Mass Update - Harvest (R40G0300).
Run the mass harvest update program.
Use the Mass Update - Harvest program to update harvest attributes. This is a two-step process. First, you must create a harvest record update profile. This profile specifies which fields the system updates and the new values. The second step is to launch the report. The system updates the fields on all records that are identified in the program's data selection.
Access the Add/Edit Grower Harvest Update Profile form. Select the check box for each field or attribute that is being changed, and enter the new value.
Figure 5-10 Add/Edit Grower Harvest Update Profile form
Enter a unique description of a mass update profile for the grower harvest.
To make changes to the harvest header information, select the check box for these fields and enter the new value:
field | field | field |
Update Harvest Name | Update Harvest Status | Update Grower Composition Code |
Update Grower Representative | Update Blend Representative | Update Contract Representative |
Update Current Quality | Update Target Quality |
Select the Estimates tab.
Figure 5-11 Add/Edit Grower Harvest Update Profile form: Estimates tab
To make changes to the harvest estimates information, select the check box for these fields and enter the new value:
Update Confidence of Supply | Update Planned Maturity Date | Update Cut Date |
Update Planned Estimate | Update Current Estimate | Update Current Estimate Date |
Update Maturity Program Name | Recalculate Maturity Date |
Select the Location tab.
To make changes to the harvest location information, select the check box for these fields and enter the new value:
Update Growing Area | Update Appellation | Update Variety Code |
Update District | Update Region | Update County |
Update State |
Figure 5-12 Add/Edit Grower Harvest Update Profile form: Attributes 1 tab
Update Material Type | Update Irrigation Type | Update Irrigation Volume |
Update Pruning Method | Update Soil Type | Update Clone |
Update Root Stock | Update Grower Attribute 01 | Update Grower Numeric 01 |
Update Grower Numeric 06 | Update Row Spacing | Update Plant Spacing |
Update Number of Plants | Update Gross Area | Update Planted Date |
Update Extraction Rate |
Update Grower Attribute 02 - 15 | Update Grower Checkbox 01 - 05 | Update Grower Date 01 - 08 |
Update Grower Numeric 02 - 05 |
Update Container Type | Update Quantity Per Load | Update Last Load |
Update Extraction Complete | Update Quarantined Flag | Update Default Price |
Update Supplier Number | Update Parcel Number 3 Area |
These processing options control whether the system runs in proof or final mode and specify which profile to use.
Specify whether the system run in proof or final mode. Values are:
Enter the update profile ID that determines which harvest values you want to update.
This processing option controls the version of the Add/Update Harvest program that the system uses.
Enter the version of Add/Update Harvest program (P40G03) for the system to use.
Select Periodic Processing (G40G121), Harvest Record Mass Update.
When you run the Harvest Record Mass Update (R40G0300) program, the system updates the fields on the harvest record based on the fields and values that you specified in the update profile from the processing options.
If the update includes the maturity date calculation program, the system performs the update only if the harvest status is Current or Future.
If the Harvest Record Mass Update program uses a version of the Grower Harvest Maintenance program (P40G03) that creates purchase orders, the system creates or updates purchases orders when you revise harvest estimates.
This section provides an overview of performing a harvest roll and discusses how to:
Run the Harvest Roll program.
Set processing options for Harvest Roll (R40G0560).
The system enables you to create new harvest records based on existing harvests. The Harvest Roll program (R40G0560) uses the Maximum Harvest processing option for the Grower Harvest Maintenance program (P40G03) to identify the planning window that controls the number of new harvest records that the system creates.
This program rolls only harvests that are at a status of Closed and are in the Current harvest period. For example, if the harvest pattern is ANNUAL and the current period for the ANNUAL pattern is 2007, then only harvests with a harvest pattern of 2007 and a status of Closed are selected by the program to be rolled.
The program attempts to create the number of harvests that are specified by the Maximum Harvest processing option. The system either prints a message stating that No Harvest Periods Eligible to Roll for a particular harvest or lists the harvests that are or were rolled for a particular harvest.
New harvest records are created in a Future status.
Select Advanced and Technical Operations (G40G131), Harvest Roll.
Use these processing options to control system processing and to define default versions.
This processing option controls whether the program runs in proof or final mode.
Specify whether the system generates the report in proof mode or final mode. Proof mode prints the harvest records that are created but does not perform table updates. Final mode creates new harvest records, updates the Grower Harvest table (F40G03), and prints the harvest record. Values are:
This processing option determines the version that the system uses to create a rolled up harvest estimate.
Specify the version of the Grower Harvest Maintenance program (P40G03) that the system uses. Review the version's processing options, specifically Maximum Number Of Harvests To Be Created, to ensure that the version meets your needs.
If the Harvest Roll program uses a version of the Grower Harvest Maintenance program that creates purchase orders, the system creates or updates purchases orders when you revise harvest estimates.
This section provides an overview of expense spreading and lists forms used to spread expenses for harvests.
Periodically, you must spread costs across active harvest records that do not accrue to the harvest directly from operations that are performed on the harvest. For example, you might allocate indirect costs, such as utility expenses, overhead costs, equipment maintenance, taxes, depreciation, and general labor and administration costs to harvests. These costs are allocated per acre. To determine the rate per ton of harvested product, the total annual expenses for a harvest block is divided by yield in tons. Without the ability to spread expenses, harvest costs are understated in the system.
You can use the Inventory by Vessel View program (P31B81) to locate the harvests to which you want to spread expenses. To locate harvests, you use either the Harvest check box on the form or the processing option on Vessel Class Search tab. You can select multiple harvests.
You spread expenses using the Expense Spread grid on the Inventory by Vessel View form. This area of the form becomes available to use if you set the Enable Expense Spreading processing option for the Inventory by Vessel View program. In the grid, the system displays the expenses for the selected harvests by cost component.
To spread expenses to harvests, you can use any configured operation that you have set up to allow changes to lot costs. After you select harvests for expense spreading, you access the Create Operation or WO from List program (P31B78) to generate the operations that allocate the costs to the different cost components of the harvest or harvests. When you complete this step, the system notifies you about the number of operations that were created. You can review the expense spreading operations on the Search For Operations form.
If you locate harvests using the EUR field, the system displays costs by the portion of the cost attributed to the EUR. Costs spread by EUR are spread proportionately to the EUR quantity, not the harvest quantity.
Set the Enable Expense Spreading processing option on the Defaults tab for the Inventory by Vessel View program.
