This chapter contains the following topics:
Section 26.1, "Understanding Employee Self Service Performance Appraisals"
Section 26.2, "Reviewing a Competency Based Performance Self Appraisal"
Section 26.3, "Reviewing a Traditional Performance Self Appraisal"
Section 26.4, "Reviewing a Performance Appraisal From The Manager"
Section 26.5, "Defining Employee Goals Using Employee Self Service"
Section 26.7, "Defining Employee Goals Using Manager Self Service"
You can use employee self service (ESS) to manage performance appraisals. When a performance appraisal is due, either a human resources representative or a manager creates an employee performance appraisal and notifies you when it is ready for the review. If the company also uses performance self appraisals, you receive a message indicating that you are required to prepare and submit a performance self appraisal.
A performance self appraisal evaluates the job performance and provides historic examples of activities that you completed. After you submit the self appraisal, the system sends a message to the manager indicating that the appraisal is ready for review. If you need to make additional changes to the self appraisal after you submit it, their manager can reset the appraisal status so that you can enter changes and resubmit it.
After you submit the performance self appraisal to The manager, the manager reviews it and prepares an employee performance appraisal. The manager submits the appraisal for approval using a predefined approval hierarchy. When all approvals are complete, the manager sends a message to you indicating that the appraisal is ready for the review. You then review the appraisal, and either accept or contest it. The manager then schedules a meeting with you to review the appraisal and obtain feedback. You are normally the final step of the approval process.
Depending on the system settings, you can use one of two types of performance self appraisals: competency based or traditional (text based). A competency based performance self appraisal generates an appraisal that compares required job competencies to the demonstrated employee competencies. To complete a traditional performance self appraisal, you manually complete an appraisal template. You then review the performance self appraisal and make appropriate changes. You can also attach appropriate diary entries that provide examples of performance activities.
If you are not using ESS, you can still utilize the automated performance management system by performing pieces of the review process outside of the JD Edwards EnterpriseOne system. You then can set up the system to allow managers or human resources representatives to approve or contest the appraisals online on behalf of an employee.
This section provides an overview of competency based performance self appraisals.
Either a human resources representative or a manager creates the competency based performance appraisal. The appraisal is a system generated comparison of job competencies and demonstrated employee competencies. When you receive an email message indicating that a performance self appraisal is due, you use the Complete My Self Appraisal program (P087712) to:
Select the current self appraisal for review
Review the self appraisal for accuracy
Revise the self appraisal based on the knowledge of the performance
Add notes that document reasons for the changes
Attach performance diary entries that document work or personal activities that support changes to the ratings
Submit the self appraisal to the manager for review
When you enter the Complete My Self Appraisal program, the system automatically recognizes the address book number and displays the currently active appraisal. When the processing options are set appropriately, you can change the system generated ratings for each job and employee competency. You can also change the overall performance rating and enable the system to change the ratings for each of the job and employee competencies.
This section provides an overview of traditional performance self appraisal reviews.
Either a human resources representative or a manager initiates the traditional performance appraisal. The appraisal is a template that is stored as text in the software. When you receive an email message that a performance self appraisal is due, use the Complete My Self Appraisal program (P087712) to:
Manually complete all sections of the self appraisal, including ratings, if appropriate
Add notes that document reasons for the evaluations
When you enter the Complete My Self Appraisal program, the system automatically recognizes the address book number and displays the appropriate appraisal template.
This section provides an overview of performance appraisal from the manager reviews.
Select Employee Self Service menu (G05BESS1), Current Performance Appraisal.
When you receive a message indicating that an employee performance appraisal is ready for the review, you use the Current Performance Appraisal program (P087712) to select the appraisal and review it.
Performance reviews can be either competency based or traditional. You can add notes and attach performance diary entries to either type of performance appraisal to document the views of the ratings that appear in the appraisal.
This section provides an overview of employee goal definitions using employee self service and discusses how to:
Define employee goals using Employee Self Service.
Create a career development plan.
You can create and track personal goals as part of the performance appraisal process. Working closely with the manager, you use the employee goals feature to create an action plan for achieving higher levels of performance. You can also use this feature to track personal objectives that are not related to the organization. If the organization uses only a performance appraisal that the manager creates for you, you can work with the manager to create and track the goals. If you also complete a self appraisal, you can create and track goals for The self.
Employee goals are linked to a current appraisal. Although the system locks the appraisal after you approve the information that the manager enters, you can still create and change the goals and goal actions throughout the year.
Access the Goal Action Plans form.
To define goals for competency based appraisals:
Complete these fields to create a new employee goal:
Goal Status
Goal Type
Level you would like to achieve:
To create a new goal action suggestion, complete these fields:
Action Description
Action Status
Change Reason
Estimate Start Date
Estimate End Date
If you are updating an existing action suggestion, complete these fields:
Start Date
End Date
To move the current goal action suggestion to the Actions list, click the arrow.
To add additional goal action suggestions to the Actions list for the currently selected employee competency, repeat steps 2 through 4.
When the list of goal action suggestions is complete, click Submit to save, and then click Cancel to return to the appraisal form.
To create a career development plan:
Complete these fields:
Goal Status
Goal Type
Select the Free Form option for the Suggestion Type field.
Action Description
Action Status
Change Reason
Estimate Start Date
Estimate End Date
Start Date
End Date
To add additional goal action suggestions to the Actions list for the currently selected employee competency, repeat steps 3 through 5.
When the list of goal action suggestions is complete, click Submit to save. Then click Cancel to return to the appraisal form.
This section provides an overview of self service employee performance appraisals creation.
Human resources representatives and managers can use the performance appraisal management system to create, manage, and print performance appraisals. You use the Create Performance Appraisals program (P087711) to generate appraisals and evaluate employee job performance. These appraisals provide historic examples of activities that employees complete. Depending on the system settings, employees might be able to create performance self appraisals. After the employee submits the performance self appraisal to the manager, the manager reviews the self evaluation and prepares the manager performance appraisal.
This section provides an overview of defining employee goals using Manager Self Service.
Human resources specialists know that when organizations treat employees who contribute to the success of an organization as valuable assets, the organization and the employees mutually benefit. Employees benefit from establishing specific goals that help increase their skills, perform their jobs at a higher level, and advance their careers.
The employee goals system is linked to the performance management system so that managers have a concise method of measuring employee performance and improvement. You can create employee goals for either competency based or traditional performance appraisals. When you create a competency based appraisal, you can create employee goals for each employee competency. You can also create a separate, personalized career development plan. Using either appraisal approach, the employee goals feature is a tool that you can use to help the employees reach personal and corporate objectives.
You use the Current Performance Appraisals program (P087712) to review an employee appraisal and add employee goals. Although you normally create goals at the same time that you are reviewing an appraisal, you can add and revise them after you finish the appraisal process. After you submit the appraisal and the system locks it to prevent changes to the appraisal, you can still review and change employee goal suggestions.
The human resources department defines the competency information that is used in competency based performance appraisals and employee goals. You can use existing goal suggestions that might already exist, or you can use the Work With Competency Information form (W05104A) to add new ones. You can also create additional items in the UDC tables to support employee goals.
Before you complete the tasks in this section:
Attach goals to competencies, as needed.
Set up the category codes for employee goals (UDC 05/G1 through 05/G3, and 05/GT).
Create, review, and revise an employee performance appraisal.
