This chapter contains the following topics:
You can accurately plan for future stocking needs by reviewing item and quantity information. For example, you can:
Access information about stock items.
Access summary and detailed information about on-hand, committed, and available items.
Access and monitor supply-and-demand information to help you plan for future stocking needs.
Access item information about previous sales, current inventory quantities, and future receipts.
Review balance forward records for a specific fiscal year.
Reconcile inventory balances with the general ledger (GL) and access detailed item transaction information.
Compare the inventory balances at the end of one period with the same period end for the GL.
This table lists the types of quantities:
Quantity | Definition |
Available | The number of items that you can use based on user-defined calculations. You determine how the system calculates item availability by defining the factors that subtract from or add to the available quantity of an item. This calculation can include quantities that do not immediately affect on-hand amounts.
For example, you can set up the availability calculation to subtract any quantities that are committed to sales or work orders and add any quantities that are on purchase orders or in transit. |
On-hand | The number of items (expressed in the primary unit of measure) that are physically in stock. The on-hand quantity of items is affected by:
Available to promise (ATP) | The number of items that are uncommitted (available for sales or distribution) until the next replenishment orders arrive.
You select whether to use the basic method or the cumulative method to determine ATP. The basic method assumes:
When you use the cumulative method, which provides a running total, the system:
Other Quantity 1 and 2 | When you commit inventory for other quantities, the system assigns inventory to different types of sales and procurement documents, such as quote and blanket orders, that do not affect availability. |
You can use additional commitment methods if you are using lot processing. For example, you can define the commitment method by lot number or lot expiration date.
This diagram illustrates how the JD Edwards EnterpriseOne Inventory Management system typically commits inventory:
The system uses supply-and-demand inclusion rules to calculate the supply-and-demand quantities for an item. A manufacturing environment uses work orders to create a supply of parts or materials, whereas a maintenance environment uses work orders to create a demand for parts.
Type | Definition |
Sources of supply | Starting with the requested date on purchase orders, the system calculates the supply quantity from these sources:
Sources of demand | Starting with the requested date on sales orders, the system calculates the demand quantity from these sources:
You can compare the inventory balances to the GL at the end of a period. Because inventory transactions continue after GL periods close, the system provides a method for you to reconcile the inventory balances to the GL for any fiscal period.
You can use this information to create:
Summary level reports according to the GL classification code.
Running balance information on Item Ledger Inquiry (CARDEX).
Balance forward records.
Integrity reports.
This section provides an overview of locating item information, lists prerequisites, and discusses how to:
Build item word search information.
Set processing options for Item Word Build (R41829).
Locate items with word search.
Locate and return item information.
Define search criteria.
You might want to locate item information for a variety of reasons, such as entering changes to inventory, revising the information that is associated with inventory items, or reviewing available quantities.
You can use three methods to locate item information. The method that you select depends on the type of search criteria to use and where the method is available, as shown in this table:
Method | Definition | Availability |
Locating items with word search on the Work with Item Word Search form. | Enables you to locate items based on text stored in any of 31 fields in six tables. | This search is available from a Form exit in the Item Master or any transaction entry form (Issues, Transfers, Adjustments, and Reclassifications). |
Locating and returning item information on the Item Search Returning Quantity form. | Enables you to locate items by item number to see the available quantities, and then to return to the transaction entry form many fields of information for multiple items. If necessary, you can access the word search function to find the item number. | This search is available when you are using any transaction entry form (Issues, Transfers, Adjustments, and Reclassifications). |
Locating item information with item search on the Work With Item Search form. | Enables you to locate items by defined search text. | This search is available from a search button from the Item Number field and from the Inventory Inquiries menu (G41112). |
You can define specific criteria for an item search. Use this type of search when you know what the item is but you want to limit the search. For example, you can limit the search for an item to a specific branch/plant and supplier. You can use search text only to locate items that have search text information in the item master records. You can set up processing options to display sales or purchasing category codes that are applicable to items.
When you define search criteria, the system searches these tables for items with matching information:
Table | Information Type |
Item Master (F4101) |
Item Branch File (F4102) |
Item Location File (F41021) |
Lot Master (F4108) |
Location Master (F4100) |
The following mobile applications are available, and can be used to view item detail and availability information on a mobile device:
Product Price and Availability (Smartphone and Tablet)
These applications require system administrator configuration before they are available to individual users. Contact your system administrator to determine whether these applications are available for use.
Additionally, see the following topics in the JD Edwards EnterpriseOne Applications Mobile Enterprise Applications Implementation Guide:
Before you complete the tasks in this section, you must verify that:
The item cross-reference types for cross-reference numbers are set up in UDC table (41/DT).
Any external item numbers, such as supplier or substitute numbers, are set up in the Item Cross-Reference program (P4104).
Any internal item numbers, such as the second or third item numbers, are set up in the Item Master program (P4101).
Form Name | FormID | Navigation | Usage |
Work With Item Master Browse | W4101E | Inventory Master/Transactions (G4111), Item Master | Review items. |
Work with Item Word Search | W41829C | On the Work With Item Master Browse form, select Item Word Search from the Form menu. | Locate items with word search. |
Item Search Returning Quantity | W40ITM2F | Select Item Search from the Form menu on any of the transaction entry forms, such as the Inventory Adjustments form. | Locate and return item information. |
Work With Item Search | W41200A | Inventory Inquiries (G41112), Item Search | Search for items. |
Work with Item Cross Reference | W4104A | On the Work With Item Search form, select a record and select Cross Reference from the Row menu. | Define search criteria. |
Select Periodic Processing (G4120), Item Word Build.
You must run the Item Word Build (R41829) program to create and update the Item Word Search table (F41829). When you search for an item using item word search, the system accesses the Item Word Search table (F41829) for item information. The R41829 program extracts information from these tables:
Item Master (F4101)
Lot Master (F4108)
Item Master - Alternative Description (F4101D)
Item Cross Reference File (F4104)
You can run the program for the entire item master or by branch/plant. When you run the report by branch/plant, the processing time is significantly reduced.
You can run the Item Word Build program as often as necessary. For example, you might decide to run the program monthly, depending on the number of changes to descriptions because the system does not update the Item Word Search table when you change any of the descriptive (text) information. You can also set a processing option to clear and completely rebuild the Item Word Search table, if appropriate. If you do not clear the table, use data selection to specify the items to update.
Processing options enable you to specify the default processing for programs and reports.
Specify whether to clear the Item Word Search tables before the build. Values are:
Blank: Do not clear.
1: Clear.
Access the Work with Item Word Search form.
Figure 5-2 Work with Item Word Search form
Use the Item Search Text field to locate items. You can locate items by searching for a term that describes an entire category of objects or other descriptive term. For example, to see all the types of bicycle equipment in inventory, you can locate all items that contain bike in any of 31 fields, such as the item name, description, or search text.
Note: If you do not know the item number when you are entering transactions, use Item Word Search Build (R41829) to locate the item number. |
Access the Item Search Returning Quantity form.
Figure 5-3 Item Search Returning Quantity form
When you create inventory transactions, you can locate item information, such as location, lot number, grade, potency, expiration date, and lot status code, and return it to the transaction to save you entry time and reduce errors. Use the Item Search Returns Quantity program (P40ITM2) to locate and return the item information to the transaction. You can use the Item Search Returns Quantity program to create a transaction with multiple lines.
If you use quality mode, you can use only branch/plants and grade and potency information that is specified in the customer preferences.
Access the Work With Item Cross Reference form.
Figure 5-4 Work With Item Cross Reference form
Enter a code from UDC table (41/DT) that identifies the type of cross-reference setup for this customer. Examples of cross-reference types include substitutes, replacements, and customer or supplier item numbers.
Enter the address number of the customer or supplier.
Enter an identifier for an item.
Enter the cross-reference item number that the system assigns to an item number. A cross-reference number enables you to use a supplier's item number if it is different from the own item number when you are processing an order or printing. You set up this number in the Item Cross-Reference (P4104) program.
Enter a remark about an item.
Enter a OEM-assigned value from UDC table (40R/CD) that further describes the part number.
This section provides an overview of quantity information, lists prerequisites, and discusses how to:
Set processing options for Item Availability (P41202).
Locate summary quantity information.
Review detailed quantity information.
Set processing options for Segmented Item Availability (P41206).
Review segmented item availability.
Set processing options for Location Segment Inquiry (P4100142).
Review quantities in locations with segments.
Set processing options for Lot Master (P41280).
Locate quantity information by lot.
Set processing options for Item Ledger Inquiry (CARDEX) (Select Items for Count-Tag Inventory).
Locate on-hand quantity information.
Review current inventory levels online.
The following mobile applications are available, and can be used to review quantity information on a mobile device:
Inventory Availability (Smartphone and Tablet)
Additionally, see the following topic in the JD Edwards EnterpriseOne Applications Mobile Enterprise Applications Implementation Guide:
Quantity information includes the available and on-hand quantities for items. You use quantity information to determine the current and future inventory needs. This table lists the types of quantity calculations the system performs:
Calculation | Description |
Days available | Reflects the number of days in the future that an item will be available. |
On-hand | Reflects the total number of items in a particular branch/plant. |
Commitments | This calculation includes soft commitments, hard commitments, and quantities on work orders. |
Available | Defines how the system performs this calculation. Typically, it includes on-hand quantities minus any outstanding commitments, reservations, and backorders. |
On receipt | Reflects quantities that are on open purchase orders. |
Reorder point | Specifies the minimum item quantity for which replenishment should occur, or you can have the system calculate it. |
Economic Order Quantity (EOQ) | Determines a minimum quantity for an item based on an economic analysis of the cost of placing an order and keeping inventory. |
You can access summary quantity information about each item based on the item number and branch/plant. You can also view the total quantity of items in any of these categories:
On-hand.
Held.
Hard committed and soft committed.
Available.
Purchase and work orders.
Backorders.
You can set the Truncate/Round processing option to specify the rounding method to use in calculations. The program rounds the calculation result to the number of decimal places that are specified in the data item Quantity On Hand - Primary Quantity (PQOH). The default value in the Display Decimals field is no decimals. When this data item has no display decimals, you do not see decimals in the resulting quantity on hand.
For example, assume that you have an item with eaches as a primary unit of measure. This item has a unit of measure conversion of 10 eaches to one box. Currently, you have six eaches in stock. If you change the UOM (unit of measure) field in the heading area of the Work With Item Availability form from EA (eaches) to BX (boxes), you might expect to see 6 (6 eaches) displayed as the quantity on hand. However, with no display decimals specified, the system does not display decimal quantities. The quantity depends on the rounding method that you select:
Round or round up method: 6 boxes (6 eaches) displays as 1 box.
Truncate method: 6 boxes (6 eaches) displays as 0 (zero) boxes.
You can change the rounding method on the Work With Item Availability form (Additional Selections 1 tab). In that case, the system interactively recalculates and displays the quantity.
You can locate all of the items in a specific location within a branch/plant and review detailed information for each item in the location. You can review availability for an item in a specific location by accessing the Detail Availability program (P41202).
You can view detailed quantity information about an item in a specific storage area and verify the quantity committed compared to the quantity in the storage area.
In the branch/plant constants, you can define availability calculations, which include:
Quantities that subtract from availability, such as soft commits, hard commits, and future commits.
Quantities that add to availability, such as purchase order receipts and quantities.
You can review availability information in quality mode if you:
Activate the JD Edwards EnterpriseOne Quality Management system on the Quality Management Setup menu (G3741).
Enable the Quality Control constant in the Branch/Plant Constants for each branch plant to include in quality tests.
To review only the records that passed quality testing, set the related processing option for Summary Availability. In quality mode, you can enter an address book number. The system does not enable changes to the Branch/Plant, Grade Range, or Potency Range fields, regardless of the processing options settings. The system displays only the branches that are set up in the user preferences.
You can set processing options that enable you to:
Indicate the available quantity in both primary and requested units of measure when the requested unit of measure is not the primary unit of measure.
Review available information in Shopping Cart mode.
In this mode, the address book number appears. Not all fields that usually appear in the detail area are available in this mode.
Before you complete the tasks in this section, you must:
Set up the system to calculate availability for manufacturing processes if you are using the JD Edwards EnterpriseOne Product Data Management system.
Set up location segments.
Verify that the system is set up to calculate availability for inventory items.
See Setting Up Constants.
Work With Item Availability | W41202A | Inventory Inquiries (G41112), Summary Availability | Locate summary quantity information. |
Work With Item Availability | W41202A | Inventory Inquiries (G41112), Detailed Availability | Locate detailed quantity information. |
Detail Availability | W41202C | On the Work With Item Availability form, select Detail Avail. from the Row menu. | Review detailed quantity information. |
Work With Segmented Item Availability | W41206A | Inventory Inquiries (G41112), Segmented Item Availability | Review segmented item availability. |
Work with Shipping Availability | W41206B | On the Work With Segmented Item Availability form, select Shipping Avail. from the Row menu. | Review shipping availability. |
Location Segment Inquiry | W4100142B | Inventory Inquiries (G41112), Location Segment Inquiry | Review quantities in locations with segments. |
Work With Lot Availability | W41280B | Lot Control (G4113), Lot Availability | Locate quantity information by lot. |
Work With Item Ledger | W4111A | Inventory Inquiries (G41112), Item Ledger (CARDEX) | Locate on-hand quantity information. |
Work With Inventory Quantities | W41201A | Inventory Inquiries (G41112), Supplier Self-Service Inventory | Review current inventory levels online. |
If you leave any of the following processing options blank, the system uses the ZJDE0001 version.
Specify which version of the Item Master (P4101) program to use.
Specify which version of the Item Notes (P40163) program to use.
Specify which version of the Item Search (P41200) program to use.
Specify which version of the Purchase Order Inquiry (P430301) program to use.
Specify which version of the Customer Service Inquiry (Misc. Windows) program (P42045) to use.
Specify which version of the Open Work Orders (R31400) program to use.
Specify which version of the Supply and Demand Inquiry (P4021) program to use.
Specify which version of the Bill of Material Inquiry (P30200) program to use.
Specify which version of the Lot Master Availability (P41280) program to use.
Specify which version of the Item Ledger Inquiry (CARDEX) program (P4111) to use.
Specify which version of the Branch/Plant Constants (P41001) program to use.
Specify which version of the Location Master (P4100) program to use.
Specify which version of the Item Location Type (P41023) program to use.
Specify whether the system displays grade information. Values are:
Blank: Do not display.
1: Display.
Specify whether the system displays potency information. Values are:
1: Display.
Specify whether the system displays information from the JD Edwards EnterpriseOne Quality Management system. Values are:
1: Display.
Specify whether the system displays quantity information in primary units of measure. Values are:
1: Display.
Specify the manner in which the system truncates or rounds the information in the detail area. Values are:
Blank: Round the information in the detail area. The system uses normal mathematical rounding. For example, with no display decimals specified, 2.3 remains 2 and 2.6 is rounded up to 3.
1: Truncate the information in the grid. The system always removes additional positions. For example, with no display decimals specified, 2.3 and 2.6 are both truncated to 2.
2: Round up the information in the grid. The system always rounds to the next higher number. For example, with no display decimals specified, 2.3 and 2.6 are both rounded up to 3.
Specify whether the system uses the standard mode or customer self-service functionality. Values are:
Blank: Bypass customer self-service functionality and use the standard mode.
1: Activate customer self-service functionality.
Specify whether the system displays the Percent of Life Remaining field.
Specify whether the system displays the Number of Days Remaining field.
Specify a date that the system uses to calculate the remaining number of days until a lot expires. If you leave this processing option blank, the system uses today's date.
Access the Work With Item Availability form.
Figure 5-5 Work With Item Availability form
Note: The system does not display decimal quantities if the Display Decimals field in the Quantity On Hand-Primary Quantity (PQOH) data item has no display decimals specified (default). |
Select the Item Availability tab.
Select this check box to indicate that the system will display information that is summarized by item, company, currency code, and cost rule. If you do not select this check box, the system displays individual receipt records.
Select this check box to indicate that the system does not display information with zero on-hand quantities. If you do not select this check box, the system displays information with zero on-hand quantities.
Enter the number of units that are physically in stock. The system displays the quantity on-hand in the primary unit of measure.
Enter the total quantity that is committed to a specific location. The total quantity is the sum of all quantities that have been sold, soft committed, or hard committed to sales orders and work orders.
Enter a number that indicates the quantity that is available. For example, the available quantity might consist of the on-hand quantity minus commitments, reservations, and backorders.
Availability is user-defined. You can set up availability in the Branch/Plant Constants (P41001) program.
Enter the total number of items that are on receipt for a specific location. The total is the sum of all quantities of an item that are on order and in route for a location.
Enter the number of units that are soft committed to sales orders or work orders in the primary units of measure.
Enter the number of units that are committed to a specific location and lot.
Enter the quantity on sales order for which the requested shipment date is beyond the standard commitment period that has been specified in the branch/plant constants for that branch. As an example, if you normally ship most orders within 90 days, then an order for an item with a requested ship date a year from now would have its quantity reflected in this field.
Enter the number of units that are backordered in primary units of measure.
Enter the number of units that are hard committed to work orders in the primary unit of measure.
Enter the first of two quantities that can be specified as additional offsets (subtractions from on-hand) in the determination of quantities available for sale (primary unit of measure).
Enter the second of two quantities that can be specified as additional offsets (subtractions from on-hand) in the determination of quantities available for sale (primary unit of measure).
Enter the number of units specified on the purchase order in primary units of measure.
Enter the quantity that appears on documents such as bid requests, which are not formal commitments to buy on the part of the organization.
Enter the quantity that is currently in transit from the supplier.
Enter the quantity that is currently being inspected. This quantity is received, but is not considered on hand.
Enter the quantities that are currently at a user-defined operation within the dock-to-stock process. The quantity is received, but may or may not be considered to be on hand.
Select the Additional Selections 1 tab.
Figure 5-6 Work With Item Availability form.
Enter a code from UDC table (40/LG) that indicates the minimum grade that is acceptable for an item.
The system displays a warning message if you try to purchase or issue items with grades that do not meet the minimum grade acceptable. The system does not enable you to sell items with grades that do not meet the minimum acceptable level.
Enter a number that indicates the minimum potency or percentage of active ingredients that is acceptable for an item.
The system displays a warning message if you try to purchase or issue items that do not meet the minimum acceptable potency. The system does not enable you to sell items that do not meet the minimum acceptable potency.
Access the Detail Availability form.
Enter the number of units that are back ordered in primary units of measure.
Enter the number of units hard committed to work orders in the primary unit of measure.
Enter the first of two quantities that can be specified as additional offsets (subtractions from on-hand) in the determination of quantities that are available for sale (primary unit of measure).
Enter the second of two quantities that can be specified as additional offsets (subtractions from on-hand) in the determination of quantities that are available for sale (primary unit of measure).
Enter the number of units that are specified on the purchase order in primary units of measure.
Enter a template name that you can use when entering items in the Item Master Revisions (P4101) program. The name is case sensitive.
Specify the version of the P41202 program to use. If you leave this processing option blank, the system uses version ZJDE0001.
Access the Work With Segmented Item Availability form.
Figure 5-8 Work With Segmented Item Availability form
You can view item availability from the Work With Segmented Item Availability form:
Select Item Availability from the Row menu to access the Work With Item Availability form, which displays the item availability by segment with access to Item Availability.
Shipping availability
Select Shipping Avail. (shipping availability) from the Row menu to access the Work With Shipping Availability form, which displays the unit of measure structure for the warehouse and the quantity that you have available to ship for each unit of measure.
If you have many different segmented items with different templates, you might want to set up different versions of the Segmented Item Availability program (P41206) with a different template identified in each version. You can set the processing options in the Item Master program (P4101) to use a default template. You can also override the default template.
If you leave the On Hand Primary U/M field blank, the system selects the primary unit of measure for the first item found.
Specify the mode in which to run the program. Values are:
Blank: Client mode
1: Web mode
The system displays only the item and location information that is related to you based on the user ID and address book number. If you are signed into the system using the web, Item Availability is disabled.
Access the Location Segment Inquiry form.
You can review the inventory balances for items that are assigned to locations with segments by:
Product
You can view the balance for the current product in any or all of the segments in the location.
Segment
You can select specific segments and view the balance for all owners within that segment of the location.
Address book number
If you have set one of the segments as an address book record, you can view all balances for all locations and products by the specified owner or address book number.
Select this check box to display individual receipt records. If you do not select this check box, the system displays information that is summarized by item, company, currency code, and cost rule.
Select this check box to display information with zero on-hand quantities. If you do not select this check box, the system does not display information with zero on-hand quantities.
Specify the version of the Trace/Track Inquiry (P41203) program to use.
Specify the version of Item Master (P4101) program to use.
Specify the version of Work Order Entry (P48204) program to use.
Specify the version of Item Branch/Plant (P41026) program to use.
Specify whether to update the lot status. Values are:
Blank: Update.
1: Do not update.
Specify whether to display the grade range. Values are:
1: Display.
Specify whether to display the potency range.
1: Display.
Access the Work With Lot Availability form.
Figure 5-10 Work With Lot Availability form
You can review the number of items that are in a specific lot, as well as the activity dates, item quantities, and hold statuses that pertain to the lot. The activity date and quantity information reflect transactions such as issues, receipts, and sales. If the same item or lot appears more than once, the item exists in multiple locations.
Enter the number that identifies a lot or a serial number. A lot is a group of items with similar characteristics.
Enter the number that the system assigns to an item. The value can be in short, long, or third-item number format.
Enter the code that indicates the grade of a lot. The grade is used to indicate the quality of the lot. Examples include:
A1: Premium grade
A2: Secondary grade
The grade for a lot is stored in the Lot Master table.
Enter the code that indicates the potency of the lot expressed as a percentage of active or useful material (for example, the percentage of alcohol in a solution). The actual potency of a lot is defined in the Lot Master table.
Select whether to display all lots or with quantity on hand.
Specify a user-defined code from UDC table (00/DT) that identifies the document type. If you leave this processing option blank, the system uses the default value* and all document types appear.
Specify the version to be used for each program. If this processing option is left blank, the system uses version ZJDE0001.
Enter 1 to display quantity in primary units of measure along with quantity in transaction units of measure.
Access the Work With Item Ledger form.
On-hand quantity is the number of items that are physically in stock. You can locate on-hand quantity and accounting information for a specific transaction date and document number in the Item Ledger Inquiry (CARDEX) (P4111). The Item Ledger Inquiry (CARDEX) contains transaction history such as sales, receipts, or transfers for each item in the inventory. Each entry represents a transaction that affects the on-hand quantity of an item.
You can review a transaction to determine both item quantities and the related costs in any branch, location, or lot as of a particular date. You can also see any transactions for that item that have taken place as of a specific date and locate information about quantities that are deducted from the on-hand quantity.
Enter a value that represents the available quantity, which might consist of the on-hand balance minus commitments, reservations, and backorders. This is calculated in the Branch/Plant Constants program (P41001).
Access the Work With Inventory Quantities form.
Figure 5-12 Work With Inventory Quantities form
Suppliers can review inventory levels online to inquire on the items that they supply in order to maintain a predictable delivery of goods and services. Suppliers can check the availability and on-hand quantity of items so that they can determine whether to use Supplier Self-Service programs to create purchase orders or to issue quotes. Suppliers can also prepare for future activity by gathering information on particular trends and anticipating surpluses and shortages.
Using their item number, the suppliers can review information such as branch/plant, quantity on-hand, quantity on purchase order, location, lot/serial number, and short item number. Suppliers can also have the system display the information in summary to detail mode.
This section provides an overview of supply-and-demand information and discusses how to:
Set processing options for Supply and Demand Inquiry (P4021).
Review supply and demand information.
Use the Supply/Demand Inquiry (P4021) program to review demand, supply, and available quantities for a specific item. You can review general product and item performance for a specified branch/plant, as well as past sales performance, current demand, and other item information. The information is based on inventory, purchasing, and sales history.
The highlighted available-to-promise (ATP) lines on the Supply/Demand Inquiry form indicate the company's uncommitted available inventory. Available-to-promise inventory is available for sale or distribution within a specified period.
The demand quantities are listed by date and can include safety stock, quantities on sales orders, work order parts lists, planned order demand for lower levels, and interplant and forecasted demand.
The supply quantities are listed by date and can include on-hand inventory and quantities on purchase orders, manufacturing work orders, planned orders, and rate schedules. Supply quantities without a date or order information represent current availability by branch/plant storage location.
You can also access these forms to confirm detail information:
Work With Order Scheduling
Parts Availability
Work With Detail Messages
Work With Time Series
Work With Pegging Inquiry
Plant Manufacturing Data
The system displays information from these tables:
Item location File (F41021)
Sales Order Detail File (F4211)
Purchase Order Detail File (F4311)
Work With Supply and Demand | W4021B | Inventory Inquiries (G41112), Supply and Demand | Review supply-and-demand information. |
Specify whether the system deducts the safety stock from the available quantity. Values are:
Blank: Do not deduct.
1: Deduct.
Specify whether to consider receipt routing quantities as on hand. Values are:
Blank: Do not consider.
1: Consider.
Specify whether the system considers the quantity in transit a part of the on-hand quantity. In a manufacturing environment, sometimes you must establish where stock is to determine whether it is available for immediate use. Values are:
Blank: The system displays the quantity in transit for the appropriate date.
1: The system includes quantity in transit as on-hand inventory.
Specify whether the system considers the quantity in inspection a part of the on-hand quantity. Values are:
Blank: The system displays the quantity in inspection for the appropriate date.
1: The systems includes quantity in inspection in on-hand inventory.
Specify whether the system considers the user-defined quantity 1 and user-defined quantity 2 as parts of the on-hand quantity. This quantity is defined in the Update Operation 1 and Update Operation 2fields on the Receipt Routing Definition form. Values are:
Blank: The system displays the quantities for the appropriate date.
1: The system includes the user-defined quantity 1 in the on-hand inventory.
Specify a user-defined code from UDC table (40/RV) that identifies the supply-and-demand inclusion-rules version for the system to use.
Specify whether the system subtracts the expired lot quantities from the available quantity. Values are:
Blank: Do not subtract the expired lots.
1: Subtract expired lots.
Note: This processing option does not work with available-to-promise lines. If you enter 1 in this processing option, you must set the Available to Promise Line Flag processing option, under the Process 1 Tab, to either blank or 2. |
Specify whether the system enables Engineer-to-Order (ETO) functionality. Values are:
Blank: Do not enable ETO functionality.
1: Enable ETO functionality.
Specify whether to include past-due quantities while calculating available quantity. Values are:
Blank: Do not include.
1: Include.
Specify a user-defined code from UDC table (31/ST) that identifies the rate-based schedule type for the system to display. If you leave this processing option blank, the system does not display any rate-based schedules.
Specify whether to display planned orders from MPS (Master Planning Schedule) /MRP (Material Requirements Planning)/DRP (Distribution Requirements Planning) generations. Values are:
1: Display.
Specify which forecast types, up to five, the system includes in the inquiry. If you leave this processing option blank, the system does not include any forecast records.
Specify the number of days (+ or –) from the system date that you want the system to include forecast records. If you leave this processing option blank, the system includes records from today.
Specify whether to display bulk stocking type records. Values are:
Blank: Display bulk items.
1: Do not display bulk stocking type records.
Specify whether to use open quantity from past-due rate schedules as supply. Values are:
Blank: Do not use.
1: Use.
Note: When you enter 1, the system includes past-due orders in the rate schedule unadjusted (+RSU) and rate schedule adjusted (+RS) lines in the Master Planning Schedule - Multiple Plant (R3483) and the MRP/MPS Requirements Planning (R3482) programs. |
Specify the start date. Values are:
Blank: Use the system date.
1: Use the start date of the current forecast period.
Note: If you enter 1, the Enable Engineer to Order processing option must be blank. |
Specify a maximum of five lot hold codes from UDC table (41/L) that identifies the lots to be included in the calculation of on-hand inventory. Values are:
Blank: Include no held lots in calculation of on-hand inventory.
* : Include all held lots in calculation of on-hand inventory.
Specify whether to convert quantities to the standard potency. Values are:
Blank: Do not convert.
1: Convert.
Specify whether the system displays an ATP line, a cumulative available to promise line (CATP), or neither. Values are:
1: Display ATP line.
2: Display CATP line.
Note: If you enter 1, you cannot use the Subtract Expired Lot Quantities processing option. |
Specify whether the system summarizes all quantities for the In Receipt routing steps into one line. Values are:
Blank: Do not summarize.
1: Summarize.
Specify whether the system summarizes all the quantities in the item location records into one line. Values are:
1: Summarize.
Specify whether the system displays the Supply & Demand Inquiry (P4021) program in the window format if it is called from another program. Values are:
Blank: Display the program in the full-form format.
1: Display the program in window format.
Specify whether to summarize pegging and parts list demand: Values are:
1: Summarize.
Specify the version of the P4310 program to use.
Specify the version of the P4210 program to use.
Specify the version of the P31225 program to use.
Specify the version of the P3412 program to use.
Specify the version of the P3413 program to use.
Specify the version of the P3411 program to use.
Specify the version of the P30200 program to use.
Specify the version of the P41026 program to use.
Specify the version of the P48013 program to use.
Specify the version of the P3109 program to use.
Access the Work With Supply and Demand form.
Figure 5-13 Work With Supply and Demand form
Enter the date that an item is scheduled to arrive or that an action is scheduled for completion. Values include:
Promise Date: The planned effective date for work orders and purchase orders.
Requested Date: The planned effective date for sales orders.
Lot Effective and Lot Expiration Date: The planned effective date for lots.
Forecast Date: The planned effective date for forecast.
Enter a code from UDC table (00/UM) that specifies the quantity in which to express an inventory item.
Enter the number of units that are committed for shipment in Sales Order Entry. Use either the entered or the primary unit of measure that is defined for this item.
In the Manufacturing system and Work Order Time Entry, this field can indicate completed or scrapped quantities. The quantity type is determined by the type code entered.
Enter a value that represents the available quantity, which might consist of the on-hand balance minus commitments, reservations, and backorders. You enter this value in the Branch/Plant Constants (P41001) program.
Availability is user defined. You can set up availability in the Branch/Plant Constants program (P41001).
Enter a number that identifies an original document. This document can be a voucher, sales order, invoice, unapplied cash, journal entry, and so on.
Enter a code from UDC table (00/DT) that identifies the type of document. This code also indicates the origin of the transaction.
Set processing options for Buyer Information (P4115).
Review performance information.
Work With Buyer's Item Information | W4115A | Inventory Inquiries (G41112), Buyer's Information | Review performance information. |
If you leave any of the following processing options blank, the system uses version ZJDE0001.
Specify the version of the P43230 program to use.
Specify the version of the P41061 program to use.
Specify the version of the P4021 program to use.
Access the Work With Buyer's Item Information form.
Figure 5-14 Work With Buyer's Information form
When you review performance information for an item, you can review buyer information that is related to the item, previous sales activity, and open purchase orders. This information, when used in conjunction with item availability information, helps you to plan for the inventory needs.
Enter the address number of the person who is responsible for setting up and maintaining the correct stocking levels for the item.
Enter a code that specifies this item's ABC ranking by sales amount. Values are:
A: Assign this item to the first (largest) amount ranking.
B: Assign this item to the second (intermediate) amount ranking.
C: Assign this item to the third (smallest) amount ranking.
D: Do not include this item when you run ABC analysis.
Three types of ABC analysis are available: sales, margin, and on-hand value. Within each type of analysis, you can have three groups: A, B, and C.
The ABC Code fields contain a percentage that tells the system how to define the A, B, and C groups for categorizing items during ABC analysis. Each group measures a total within the type of analysis.
For all groups, the system compares the appropriate sales, margin, or on-hand value totals of a single item to the appropriate total for all items and calculates the value of each item. An item's value is its percentage of the appropriate total. The system then arranges the values of all items from highest to lowest value and accumulates the percentages. What happens next depends on the group:
A group: If an item's value causes the accumulated total to exceed the A accumulated percentage, the system assigns the item to the B group.
B group: When the accumulated total reaches the percentage that you entered for items in the A group, it continues adding values until it reaches the percentage that you entered for items in the B group. The system assigns all items for which the value falls between the A and B percentages to the B group.
C group: The C group consists of items for which the accumulated value exceeds the B percentage. The percentage that you usually enter for the C group is .999.
Enter a quantity for an item that specifies when replenishment occurs. Typically, this occurs when the total quantity on hand plus the quantity on order fall to or lower than a specified quantity. You can enter this quantity, or the system can calculate it if a sufficient sales history is available.
Enter the estimated reorder quantity for an item. You can enter this quantity if not enough sales history is available for the system to accurately calculate a reorder quantity.
Enter the quantity of stock that is kept on hand to cover high-side variations in demand.
Enter a value that represents the leadtime for an item at its assigned level in the production process, as defined on Plant Manufacturing Data. The system uses this value to calculate the start dates for work orders using fixed leadtimes.
Level leadtime is different for purchased and manufactured items:
Purchased: The number of calendar days that are required for the item to arrive at the branch/plant after the supplier receives the purchase order.
Manufactured: The number of workdays that are required to complete the fabrication or assembly of an item after all the components are available.
You can enter level leadtime manually on Manufacturing Values Entry, or you can use the Leadtime Roll up program to calculate it. To calculate level leadtime using the Leadtime Roll up program, you must first enter a manufacturing leadtime quantity in the F4102 table.
Enter the branch/plant and item numbers.
This section provides an overview of transaction records and discusses how to:
Run the Item Ledger As Of Generation program.
Set processing options for Item Ledger As Of Record Generation (R41542).
Update balance forward records for inactivity in the fiscal year.
Set processing options for As Of Updating (R41548).
Enter individual transactions.
Review multiple transactions and balances.
Review the Item Ledger Detail Print report.
Set processing options for Item Ledger Detail Print (R41540).
Review the Item Ledger by GL Class Code report.
Set processing options for Item Ledger by GL Class Code (R41541).
Review the General Ledger by Object Account report.
Review the Trail Balance by Object Account report.
You can use transaction records to:
Keep accurate balance forward records from year to year.
Compare and reconcile the inventory balances for different fiscal periods.
Access information about the quantity and cost of an item in any location.
You can create balance forward records for a fiscal year by running the Item Ledger As Of Record Generation program (R41542). This program summarizes item transactions for each general ledger category code and provides the most accurate and efficient method of updating the records in the F41112 table.
When you create balance forward records, you can compare and reconcile the inventory balances at the end of one period with the same period end for the general ledger. This comparison is helpful because the system continues to record inventory transactions after the general ledger periods close.
Using the balance forward records, you can review total transactions by location and review how much of an item (both the quantity and cost amount) that you have in any specific branch, location, or lot as of a specific date. You can also review any transactions for that item that have taken place after that date.
You can keep accurate balance forward records from year to year. You create the balance forward records for item transactions by running the R41542 program. You can run this program using one of these methods:
Method | Description |
Complete regeneration | Typically, you run the R41542 program only the first time that you create the F41112 table. However, if you change the fiscal date patterns on the general ledger, you must completely regenerate this table. During a complete regeneration, the system processes the information in this way:
Partial regeneration | When you create the F41112 table for the first time, you can run this process at the end of each GL period to enter new transactions and keep the balance forward records current.
If records have been purged from the F4111 table or if you do not know whether a purge has been run, use the partial regeneration method. |
The system records a transaction for this information, using the primary unit of measure:
Data for the entire year, based on the fiscal date pattern.
Cumulative quantity and cost amount totals from the previous years.
Location.
Lot.
GL class.
Fiscal year.
When you enter individual transactions to the F41112 table, you create a record for each of the unique combinations of the levels. When one of these records changes, the system creates a new balance forward record at each level. However, the system bypasses the item ledger and GL transaction accounts.
Use this data sequence when you run the R41542 program:
Item Number - Short
Branch/Plant
Location
Lot
GL Class
GL Date
Do not delete transactions from the F41112 table. You will lose total results if you delete transactions because:
The system updates the balance-forward information but not the Item Ledger File and other general ledger transaction accounts.
The system marks any transactions that you delete as summarized in the Item Ledger File. The system does not select the transactions again if you run a partial regeneration of the Item ASOF File table.
For the R41542 report, the system loads only the records for sales orders that have been processed through sales update. The system cannot load purged item ledger records into the F41112 table. If you load purged item ledger records, there will be inaccurate totals.
Work With Direct As Of Entry | W41112AA | As Of Processing (G4122), Direct As Of Entry | Review transactions. |
Direct As Of Entry | W41112AB | On the Work With Direct As Of Entry form, click Add. | Enter individual transactions. |
Item Ledger - Running Balance Summary | W41112A | As Of Processing (G4122), Item Ledger (Running Balance) | Review multiple transactions and balances. |
Select As Of Processing (G4122), Item Ledger As Of Generation.
The Item Ledger As Of Record Generation program (R41542) creates the balance-forward records for individual transactions. Accurate balance-forward records are essential for comparing and reconciling the inventory balances. These records enable you to access information about the quantity and cost of an item in any location.
Specify whether to regenerate the entire F41112 table. Values are:
Blank: The As Of file is updated with any transactions in the F4111 table that have not yet been processed by the As Of generation.
1: Regenerate the entire F41112 table.
Specify whether to print a completion report. Values are:
Blank: Print a completion report only if errors occur.
1: Print a completion report.
To include items with no transactions in the current fiscal year in the balance forward records, select As Of Processing (G4122), As Of Updating.
The Item Ledger As Of Record Generation (R41542) program creates records in the Item ASOF File only when a record exists in the Item Ledger table. If no transaction occurs during the year for an item, the system does not create a record in the F4111 table. Therefore, the system does not subsequently create a record in the F41112 table.
To include records of prior year activity, run the As Of Updating (R41548) program after you run the R41542 program. The R41548 program searches for an item record in the Item ASOF File and then determines whether a corresponding record exists for the next year. If a record does not exist for that year, the program inserts a record, carrying forward the cumulative amounts and quantities. The program continues to fill in any gaps until processing is complete for the year that is specified in the processing options.
For example, if the first generation of the F41112 table occurs in 2007 and you specify 2010 in the processing option, the program starts with 2007 balances. If item 1001 had transactions only in 2007, the program creates records for 2008, 2009, and 2010, carrying the 2007 balances forward.
Enter a four-digit fiscal year (for example, 2008) through which the file is to be updated. If you leave this processing option blank, the system enter the current year as the default. The R41548 program will not run if you enter an invalid year.
Access the Direct As Of Entry form.
After the system generates the F41112 table, you can review item transaction and balance information for a specific fiscal period on the Work With Direct As Of Entry form. You might have to enter individual transactions if the F41112 table has been purged or if some records were damaged. You can use the R41542 program to enter these transactions.
Important: Enter only those item quantities that actually exist in the Item Ledger table (F4111). If you add entries that do not match records in the F4111 table, the Item Balance/Ledger Integrity report will have errors. In addition, you will not have an adequate audit trail to reconcile any differences. |
Enter a number that identifies the fiscal year. Generally, you can either enter a number in this field or leave it blank to indicate the current fiscal year (as defined on the Company Setup form).
Specify the year at the end of the first period rather than the year at the end of the fiscal period. For example, a fiscal year begins October 1, 2008, and ends September 30, 2009. The end of the first period is October 31, 2008. Specify the year 08 rather than 09.
Enter the item number and location information.
Enter the total amount of all transactions in the item ledger for an item.
If cumulative amounts and quantities for the previous year are in the system, the system displays them after you enter the fiscal year, branch/plant, and item number on Direct As Of Entry form. If the system does not display this information because no balance-forward records exist for the previous year, you can enter them manually. However, any amounts that you enter must match the previous year's totals.
Enter the cumulative total quantity from all transactions in the item ledger for an item.
Enter a number that represents the net amount posted during the accounting period. The system uses the accounting periods from the F0010 table. The net amount posted is the total of all debits and credits, beginning with the first day of the period through the last day of the period.
Access the Item Ledger - Running Balance Summary form.
Figure 5-16 Item Ledger - Running Balance Summary form
To review transaction history that is summarized by each fiscal period, you can use the running balance version of the item ledger. The summarized running-balance version enables you to review transaction history by the general ledger date rather than by the transaction date. The system displays the summarized information from the F41112 table only.
You also can review the individual transactions for each fiscal period by accessing each fiscal period's detailed information. The system displays information from the F41112 table and the F4111 table. You can review this information when you are preparing to reconcile the inventory and when you are tracking the original versus the general ledger document type for a transaction.
Enter a user-defined name or remark.
Future use. The historical quantity, in primary units of measure, on the bill of material.
Enter the total quantity of an item to be reworked or scrapped as a result of an engineering change order (ECO) disposition.
Select As Of Processing (G4122), Item Ledger Detail Report.
The Item Ledger Detail Print report (R41540) lists the cumulative transactions from balance forward records prior to the GL date that you select in the processing options. The GL date that you select is based on the user-defined GL dates that you set up in the processing options.
Specify the beginning general ledger date.
Specify the ending general ledger date.
Select As Of Processing (G4122), Item Ledger by GL Class Report.
Use the Item Ledger by GL Class Code report (R41541) to review the high-level totals of transactions for specific GL class and category codes. Each line of the report displays a GL classification code total for the fiscal year and period that you specify in the processing options.
The R41541 program creates the quantity and amounts for the fiscal periods that this program uses.
Do not change the sequence order of this report:
Branch/Plant
GL Class
Specify the final year and period for which the item ledger by GL class code report is to be prepared. If a fiscal period and year are not entered, the financial reporting year and period are used.
Select As Of Processing (G4122), GL by Object Account Report.
The General Ledger by Object Account report prints the general ledger in object account sequence. You can select specific transaction documents or all transaction documents. The system accesses information for this report from the F0006 and F0901 tables. The report includes:
Balance forward summaries
Account mode selection
Subledger selection
Object account summaries
Select As Of Processing (G4122), T/B by Object Account Report.
The Trial Balance by Object report prints trial balances with total postings and account balances by object account sequence. The system selects information for this report from the F0006 and the F0901 tables. The report includes:
Trial balance by object account.
Account mode selection.
Subledger selection.
Object account summaries.
This section provides an overview of Inventory to General Ledger (G/L) reconciliation processes and discusses how to:
Review the Automatic Inventory to G/L Reconciliation Report.
Set Processing Options for Automatic Inventory to G/L Reconciliation (R41500).
Run the Manual Inventory to G/L Reconciliation Program.
Set Processing Options for Manual Inventory to G/L Reconciliation (P41500).
The inventory to general ledger reconciliation process has two components:
Automatic Inventory to G/L Reconciliation (R41500), which is a batch program that automatically reconciles item ledger and general ledger documents without variances.
Manual Inventory to G/L Reconciliation (P41500), which is an interactive program you can use to:
View and manually reconcile item ledger and general ledger documents.
View and work with item ledger and general ledger documents that have already been reconciled.
View the details of selected documents in the Item Ledger grid and the corresponding details in the General Ledger grid.
When you run the Automatic Inventory to G/L Reconciliation report, the system reconciles documents where the total amount of the document in the Item Ledger matches the total amount for the same document in the General Ledger.
When you run the Manual Inventory to G/L program, the system displays summarized totals and variances by document, for all documents in your data selection. When you select a specific document, the system displays additional details from the item ledger and the general ledger. To reconcile a document, you may select adjustment journal entries you previously created to reconcile the transactions.
You can also unreconcile a previously reconciled transaction or remove adjustment journal entries previously selected to reconcile a transaction. When you unreconcile a transaction, the system clears the adjustment journal entry that you used to reconcile the transaction.
When you reconcile a transaction either by the batch process or the application, the system updates the General Ledger (F0911) records to include the reconciliation date, reconciliation code and reconciliation ID, and the Item Ledger (F4111) records with the reconciliation date.
The following diagram illustrates the Inventory to G/L Reconciliation process:
Figure 5-17 Inventory To G/L Reconciliation Process
Note: It is recommended that you use the batch process to reconcile as many transactions as possible, and subsequently use the application to manage your variances. |
Select As of Processing (G4122), Automatic Inventory to GL Reconciliation.
You can use the Automatic Inventory to G/L Reconciliation report to let the system reconcile matching records in the item ledger and the general ledger.
When you run the Automatic Inventory to G/L Reconciliation report, the system reconciles documents where the total amount of the document in the item ledger matches the total amount of the same document in the general ledger.
The system reconciles matching records by updating the general ledger (F0911) records to include the reconciliation date, reconciliation ID and reconciliation code, and by updating the item ledger (F4111) records to include reconciliation date.
Enter a code that indicates that the transaction in the Account Ledger table (F0911) is reconciled.
Specify whether the system runs the program in proof or final mode. Values are:
Blank: The system runs the R41500 in proof mode.
1: The system runs the R41500 in final mode and reconciles the transactions in Item Ledger table (F4111) and Account Ledger table (F0911).
In proof mode, the system generates a report but does not update the item ledger and general ledger tables.
Specify the earliest G/L date in a range of G/L dates that the system uses to select records from the Item Ledger table (F4111). If you leave this processing option blank the system uses the current date as the earliest G/L date in the range of G/L dates.
Specify the latest G/L date in a range of G/L dates that the system uses to select records from the Item Ledger table (F4111). If you leave this processing option blank the system uses the current date as the latest G/L date in the range of G/L dates.
Specify the additional ledger type, other than AA ledger type, for which the system updates the reconciliation details.
Enter a user defined code (00/DT) that identifies the ’work order completion' document type. If you leave this processing option blank, the system uses the document type 'IC'.
Enter a user defined code (00/DT) that identifies the ’work order issue' document type. If you leave this processing option blank, the system uses the document type 'IM'.
Enter a user defined code (00/DT) that identifies the ’lean transaction completion' document type. If you leave this processing option blank, the system uses the document type 'LC'.
Enter a user defined code (00/DT) that identifies the ’lean transaction issue' document type. If you leave this processing option blank, the system uses the document type 'LM'.
Enter a user defined code (00/DT) that identifies the ’work order scrap' document type. If you leave this processing option blank, the system uses the document type 'IS'.
Identify the order type used for interbranch orders. If you leave this processing option blank, the system uses the order type 'SI'.
Note: The processing setup for interbranch orders may cause the item ledger and general ledger amounts to be different. In this case, the system does not automatically reconcile the records. |
Specify how the system displays the records in the output. Values are:
Blank: The system displays both reconciled and variance records.
1: The system displays only variance records.
2: The system displays only reconciled records.
Specify whether the system shows the details of the item for variance records.Values are:
0: The system does not display item details.
1:The system displays item details.
Manual Inventory to G/L Reconciliation | W41500A | As of Processing (G4122), Inventory to G/L Reconciliation | Reconcile inventory to general ledger |
Access the Manual Inventory to G/L Reconciliation form.
Figure 5-18 Manual Inventory to G/L Reconciliation
To reconcile inventory to general ledger, you use the Manual Inventory to G/L Reconciliation program. The reconciliation summary grid helps you review transaction history for a given financial period. If the system displays the reconciliation date for a document in the Reconciliation Summary grid, the document is already reconciled.
When you enter a company and the transaction period, the system displays a list of all documents along with the general ledger amount, the item ledger amount, and the variance amount in the Reconciliation Summary grid. When you select a document in the Reconciliation Summary grid, the system displays the corresponding item ledger and general ledger records in the item ledger and the general ledger grids respectively.
You can reconcile documents with variances by selecting a journal entry that contains the adjustment appropriate for the transaction. To reconcile records with a variance, you select the appropriate adjustment entry and click the Reconcile button on the Reconciliation Summary grid. When you click Reconcile, the system updates the general ledger record with reconciliation date, reconciliation ID and reconciliation code, and updates the item ledger record with reconciliation date.
You can also reconcile a record without selecting an adjustment journal entry. Select a record and click the Reconcile button without selecting an adjustment journal entry. If the variance amount for the record is less than or equal to the tolerance amount specified in the processing options, the system reconciles the records by updating the item ledger record and general ledger record with the reconciliation date.
Note: If the variance amount for a record is more than the tolerance amount specified in the processing options, you must select an adjustment journal entry to reconcile the transaction. |
You can unreconcile a record that was previously reconciled. To unreconcile a record, select the record in the Reconciliation Summary grid, and click the Unreconcile button. The system updates the item ledger record by clearing the reconciliation date, and the general ledger record by clearing the reconciliation date, reconciliation ID and reconciliation code.
Enter a number that, with the document number, document type and G/L date, uniquely identifies an original document, such as invoice, voucher, or journal entry. You must enter a value in the Company field to run the Manual Inventory to G/L Reconciliation program.
Enter a date that identifies the start of the financial period.
Enter a date that identifies the end of the financial period.
Enter a number that represents the variance amount which the system uses to filter records. If you enter a value here, the system displays only those records where the variance amount is greater than or equal to the amount you enter in this field.
Use the Percentage Combo box to enter the minimum variance in the form of percentage.
Use the Include Reconciled Transactions check box if you want to view transactions which are already reconciled.
Enter a value that indicates that the transaction in the Account Ledger table (F0911) is reconciled.
Specify the additional ledger type, other than AA ledger type, for which the reconciliation details are to be updated.
Specify the tolerance amount by which the item ledger and general ledger amounts can be out of balance. If you enter an amount, you can reconcile the records with a variance up to the tolerance amount, either negative or positive.
If you leave this processing option blank, the item ledger and general ledger amounts must match.
Enter a value that identifies the ’work order completion' document type. If you leave this processing option blank, the system uses document type ”IC” .
Enter a value that identifies the ’work order issue' document type. If you leave this processing option blank, the system uses document type ”IM”.
Enter a value that identifies the ’lean transaction completion' document type. If you leave this processing option blank, the system uses document type ”LC”.
Enter a value that identifies the lean transaction issue document type. If you leave this processing option blank, the system uses document type ”LM”.
Enter a value that identifies the scrap document type. If you leave this processing option blank, the system uses document type ”IS”.
Enter the order type used for interbranch orders.
The processing setup for interbranch orders may cause the item ledger and general ledger amounts to be different. If you enter a value for this processing option, the system does not reconcile the records automatically.
