This chapter contains the following topics:
This section provides an overview of the shopping cart and lists the forms used to view and modify the contents of the shopping cart.
Before you check out and place an order, you can verify and modify the contents of the shopping cart to ensure that the order is complete and correct. After you place the order, the system updates the F4201 and F4211 tables.
Form Name | FormID | Navigation | Usage |
Add Sales Order | W4210A | From the Tasks portlet, select View Shopping Cart. | Review each line that corresponds to the items that you have selected. Modify the information as necessary. |
Order Acceptance | W42232A | On the Add Sales Order form, click Checkout. | Save changes by placing the order. |
This section provides an overview of addition items to the shipping cart, and lists the forms used to add items to the shopping cart.
If you already know which items from the product catalog you want to order, you can order the items directly, rather than using the Item Hierarchy (Web) program (P4101H).
If you use taxed prices and are adding a sales order, you have the option to select or deselect the Use Taxed Prices check box. After you process one line in the sales order, the system changes this check box to read-only.
Also, the system automatically calculates the values and displays either the domestic or foreign fields as read-only on the Product Information Add Sales Order form:
Taxed Unit Price
Foreign Taxed Unit Price
Unit Tax Amount
Foreign Unit Tax Amount
Taxed Extended Price
Foreign Taxed Extended Price
Extended Tax Amount
Foreign Extended Tax Amount
Add Sales Order | W4210A | From the Tasks portlet, select Add to Shopping Cart by Item. | Specify information such as requested date, item number, and unit of measure. |
Order Acceptance | W42232A | On the Add Sales Order form, click Checkout. | Place the order. |
