This appendix contains the following topics:
This section discusses the JD Edwards EnterpriseOne Work Orders workflow.
This section discusses the Work Order Activity Rules workflow.
The system sends approval messages for status changes based on the approval type, work order type, and estimated amount.
Changing the estimated amount or status on a work order.
The system sends an approval message to a user-defined distribution list. The status is not changed until the change has been approved.
48
WOACTRULES
W17714A, W13714A, W13714B, W90CD002A
Post Button Clicked, Post OK Button Clicked, Save Changes, Post OK Button Clicked
239, 73, 115, 154
