This chapter contains the following topics:
Section 3.1, "Activating the JD Edwards EnterpriseOne Apparel Management System"
Section 3.2, "Setting Up Next Numbers for the JD Edwards EnterpriseOne Apparel Management System"
This section provides an overview of JD Edwards EnterpriseOne Apparel Management system activation and discusses how to activate the Apparel Management system.
Before you can enter and process style item data, you must activate the JD Edwards EnterpriseOne Apparel Management system. When you activate Apparel Management, the system creates links between the JD Edwards EnterpriseOne Apparel Management system and other JD Edwards EnterpriseOne systems provided by Oracle. The JD Edwards EnterpriseOne Apparel Management system code is 41F. For you to activate system 41F, a record containing the following data must exist in the OneWorld System Control File table (F99410):
The Data Item field contains SY41F.
The Use Module field contains Yes.
You activate system 41F using the EnterpriseOne System Control program (P99410). The JD Edwards EnterpriseOne system stores system constants in the F99410 table.
Access the EnterpriseOne System Control - Revisions form.
To activate the JD Edwards EnterpriseOne Apparel Management system:
Verify that the value SY41F is in the Data Item field.
The system constant description associated with SY41F, Use Apparel Management Module, appears in the Alpha Description field.
In the Module Existence option, select Yes.
Click OK to activate the JD Edwards EnterpriseOne Apparel Management system.
Displays a code that identifies and defines a unit of information. It is an alphanumeric code up to 8 characters long that does not allow blanks or special characters such as %, &, and +. You create new data items using system codes 55–59. You cannot change the alias.
Displays a description of the data items. Enter text in uppercase and lowercase. The system uses this name to search for similar data items. To enter an alpha description, follow these conventions:
Dates: Begin all date fields with the word Date.
Amounts: Begin all amount fields with the word Amount.
Units: Begin all unit, quantity, and volume fields with the word Units.
Name: Begin all 30-byte description fields with the word Name.
Prompt: Begin any Y/N prompting field with the word Prompt.
Address Number: Begin all address numbers (employee, customer, owner) with the word Address Number.
Select an option to indicate whether a particular module has been installed in your system.
This section provides an overview of next numbers for the JD Edwards EnterpriseOne Apparel Management system and discusses how to set up next numbers for the JD Edwards EnterpriseOne Apparel Management system.
You set up standard next numbers for the JD Edwards EnterpriseOne Apparel Management system by system code. The JD Edwards EnterpriseOne Apparel Management system uses system code 41F. The system provides the following next numbers:
PriceListNumber
MasterWorkOrder
MatrixWorkFile
The MatrixWorkFile is an internal, non-customer facing next number used to make a work file unique.
Note: Next numbers are central to JD Edwards EnterpriseOne systems. You must be thoroughly familiar with next numbers before you change them. |
For next numbers:
Don't omit the next number value.
Don't change the next number value after you begin processing transactions.
Document numbers can be assigned by next numbers by system or next numbers by company and fiscal year.
For JD Edwards EnterpriseOne Apparel Management, next numbers are setup by system number.
