22 Working with Transactions for Purchase Tax
This chapter contains the following topics:
22.1 Assigning Form Types to Purchase Vouchers for an Interstate Purchase
This section provides an overview of the assignment of form types to purchase vouchers for interstate purchases, lists the forms, and discusses how to:
  • Set the processing option for Purchase CST Update (P75I2131).
  • Assign a form type to a purchase voucher for an interstate purchase.
22.1.1 Understanding the Assignment of Form Types to Purchase Vouchers for Interstate Purchases
Use the Purchase CST Update program (P75I2131) to select the records for interstate purchases and assign concession form types to purchase vouchers. For example, you assign Form C to claim the 4% central sales tax (CST) exemption for an interstate purchase.
22.1.2 Forms Used to Assign Form Types to Purchase Vouchers for Interstate Purchases
Form Name Form ID Navigation Usage
Work with Purchase Vouchers W75I2131A Purchase tax (G75I2212), Purchase CST Update Review purchase vouchers by order number, business unit, supplier number, or landed cost component.
Assign Form1 W75I2131B On the Work with Purchase Vouchers form, select a record and click Select. Assign a form type to a purchase voucher for an interstate purchase.
22.1.3 Setting the Processing Option for Purchase CST Update (P75I2131)
Processing options enable you to specify the default processing for programs and reports.
22.1.3.1 Defaults
Specify the Landed Cost Rule to be considered. These Landed Cost are with Zero Value or No Purchase Tax Component Landed Cost 1–Landed Cost 5
Specify a user-defined code from the UDC table 41/P5 to identify the purchase vouchers of the selected landed cost type for the tax update.
22.1.4 Assigning a Form Type to a Purchase Voucher for an Interstate Purchase
Access the Assign Form1 form.
Form Type
Enter a user-defined code from UDC table 75I/FS to specify the form type for sales tax concession. Examples are:
C: Form C
D: Form D
E I: Form E I
E II: Form E II
F: Form F
H: Form H
Amount Vouchered To Date
Enter the total amount of purchase orders for a voucher for a selected form type.
22.2 Entering the Form Details for Purchase Vouchers
This section provides overviews of form detail entry and revisions for purchase vouchers and discusses how to:
  • Enter the form details for a purchase voucher.
  • Revise the form details for a purchase voucher.
22.2.1 Understanding Form Detail Entry for Purchase Vouchers
Use the Form Entry program (P75I2132) to enter the form details, such as form number, form date, and state of origin for the form type that is attached to a voucher. After the purchase tax update, you can enter the form details for the vouchers of the selected form type.
The Form Entry program updates information in the Purchase Tax Form Details - Summary table (F75I402).
22.2.2 Understanding Form Detail Revisions for Purchase Vouchers
Use the Purchase Return & Form Revision program (P75I2137) to revise form details, such as form number, form receipt date, and the state issuing the purchase voucher. Before you revise the form details, you can review purchase vouchers by VAT item, CST item, or CST non four percent item on the Select Form Number form.
Using the Select Form Number form, you can also temporarily or permanently unclaim the tax for a purchase voucher by selecting Temporary/Unclaim or Permanent/Unclaim from the Row menu. You can also initiate the return of purchased items for a purchase voucher by selecting Purchase Return from the Row menu.
22.2.2.1 Purchase Returns for Goods Under Warranty or Maintenance
Follow these standard procedures to process purchase returns:
  1. Process the receipt of the goods.
    The system uses the landed cost setup to calculate and apply taxes.
  2. Enter negative amounts on a purchase order to reverse the receipt when goods are returned or rejected.
    The system uses the landed cost setup to reverse the taxes.
22.2.3 Forms Used to Enter the Form Details for Purchase Vouchers
Form Entry W75I2132A Purchase tax (G75I2212), Form Entry Review the purchase vouchers for a specific form type.
Fill Form Details - Final W75I2132C On the Form Entry form, select a record and click Select. Enter the form details for a purchase voucher.
Select Form Number W75I2137A Purchase tax (G75I2212), Purchase Return & Form Revision Review form details for purchase vouchers by VAT items, CST items, or CST non 4% items.
Form Revision W75I2137B On the Select Form Number form, select a record and click Select. Revise form details for a purchase voucher.
22.2.4 Entering the Form Details for a Purchase Voucher
Access the Fill Form Details - Final form.
Form Number
Enter the form number of the form.
Origin State
Enter a user-defined code from UDC table 00/S to specify the state from which the shipment originates.
Form Date
Enter the date on which the form was submitted for processing.
22.2.5 Revising the Form Details for a Purchase Voucher
Access the Form Revision form.
Order Type
Enter a user defined code from UDC table 00/DT that identifies the origin and purpose of the transaction. JD Edwards EnterpriseOne reserves several prefixes for document types, such as vouchers, invoices, receipts, and time sheets.
The reserved document type prefixes for codes are:
P: Accounts payable documents
R: Accounts receivable documents
T: Time and pay documents
I: Inventory documents
O: Purchase order documents
S: Sales order documents
22.3 Printing the List of Items Used for Personal Consumption
  • Run the Items Used for Personal Consumption (R75I2134) program.
  • Set processing options for Items Used for Personal Consumption (R75I2134).
22.3.1 Running the Items Used for Personal Consumption (R75I2134) Program
Run this report to print a list of the items used for personal consumption. VAT is not charged on goods used for personal consumption. In final mode, this report updates the VAT offset amount in the Consolidated tax payment table (F75I404).
Select Purchase Tax (G75I2222), Items Used for Personal Consumption.
22.3.2 Setting Processing Options for Items Used for Personal Consumption (R75I2134)
22.3.2.1 Display
Month and Year
Specify the numerical month and year for which you process personal consumption records.
Proof or Final Mode
Specify the mode in which the system runs the VAT update. Values are:
0: Proof mode. The system prints a report but does not update any tables.
1: Final mode. The system prints a report and updates the F75I404 table.
22.4 Updating Purchase Orders for VAT Items
  • Run the VAT- Purchase Update program.
  • Set processing options for VAT- Purchase Update (R75I210).
22.4.1 Running the VAT- Purchase Update Program
Use the VAT- Purchase Update program (R75I210) to print a list of purchase orders that are applicable for VAT for a specific date range. The program prints all the purchase orders with item category codes E and C that are stored in the Item Category Code Relationship table (F75I407).
Select Purchase Tax (G75I2212), VAT- Purchase Update.
22.4.2 Setting Processing Options for VAT- Purchase Update (R75I210)
22.4.2.1 Update
Proof or Final Mode
0: Proof mode. The system prints a report, but does not update any tables.
1: Final mode. The system prints a report and updates the F75I402 table.
22.5 Updating Purchase Orders in India
This section provides an overview of purchase order updates and discusses how to:
  • Update purchase order details.
  • Update purchase order details - Dealers First Stage.
  • Update purchase order details - Dealers Second Stage.
22.5.1 Understanding Purchase Order Updates
After you generate a purchase order, you use the Purchase Order Receiver Tag File – IND – 43 program (P75I008) to enter required information about the manufacturer or importer, such as the manufacturer or importer number, invoice number, and invoice date. The system stores purchase order information in the Purchase Order Receiver Tag File table (F75I008). The F75I008 table contains information about the tax regime, tax type, and excise chapter number for each purchase order received. You use the Dealer - RG23D Register report (R75I307) to review the manufacturer or importer details.
22.5.2 Forms Used to Update Purchase Orders
Work With Purchase Order Receiver Tag File W75I008A Enter P75I008 in the Fast Path. Review purchase order records.
Update Purchase Order Receiver Tag File W75I008B On the Work With Purchase Order Receiver Tag File form, select a record and click Select. Update purchase order details.
Dealer First Stage - Update PUR Tag File W75I008F On the Work With Purchase Order Receiver Tag File form, select a record and select Dealer First from the Row menu. Update the purchase order details of the dealer at first stage.
Dealer Second Stage - Update PUR Tag File W75I008C On the Work With Purchase Order Receiver Tag File form, select a record and select Dealer Second from the Row menu. Update the purchase order details of the dealer at second stage.
22.5.3 Updating Purchase Order Details
Access the Update Purchase Order Receiver Tag File form.
Recoverable
Enter a user-defined code from UDC table 75I/RF to specify whether the tax is recoverable. Values are:
N: Nonrecoverable
Y: Recoverable
Assessable Value
Enter the value on which the tax calculations are based.
Deferred Date
Enter the date from which the cenvat credit amount is available.
22.5.4 Updating Purchase Order Details - Dealer First Stage
Access the Dealer First Stage - Update PUR Tag File form.
Customs House
Enter the customs house details of the importer.
22.5.5 Updating Purchase Order Details - Dealer Second Stage
Access Dealer Second Stage - Update PUR Tag File form.
Original Manufacturer or Importer
Enter the address number of the manufacturer or importer.
Original Invoice Number
Enter the invoice number of the goods received from the manufacturer or importer.
Original Invoice Date
Enter the invoice date of the goods received from the manufacturer or importer.
Original Unit of measure
Enter a user-defined code form UDC table 00/UM that identifies the unit of measure in which you receive the item from the manufacturer or importer.
Original Customs House
Enter the customs house details of the original importer who procured the goods and passed them on to the dealers.
Original Unit Amount of Duty
Enter the duty amount per unit for the line item listed in the purchase order.
Original Total Duty
Enter the total original duty of the manufacturer or importer.
Original Duty Rate %
Enter the original duty rate percentage for the manufacturer or importer.
22.6 Updating Purchase Taxes for Purchase Vouchers
This section provides an overview of purchase tax update for purchase vouchers, lists a prerequisite, and discusses how to assign a form type to a purchase voucher.
22.6.1 Understanding Purchase Tax Update for Purchase Vouchers
To update the purchase tax that is applicable for a supplier, assign a form type code to the purchase voucher using the Purchase Tax Update program (P75I4131). You can use the Work with Purchase Vouchers form to review purchase vouchers for a specific landed cost component, supplier, and so on, and then update the associated purchase vouchers with form type codes. When you assign a form type code to a purchase voucher, the system updates the applicable purchase tax and stores the information in the Purchase Tax Form Details table (F75I402).
22.6.2 Forms Used to Update Purchase Taxes for Purchase Vouchers
Work with Purchase Vouchers W75I4131A Purchase Tax (G75I413), Purchase Tax Update Review purchase vouchers by order number, business unit, supplier, and landed cost component.
Assign Form W75I4131B On the Work With Purchase Vouchers form, select a purchase voucher and click Select. Assign a form type to a purchase voucher.
22.6.3 Assigning a Form Type to a Purchase Voucher
Access the Assign form.
Form Type
Enter a user-defined code from UDC table 75I/FS to specify the form type for purchase tax concession. Examples are:
C: Form C
D: Form D
E I: Form E I
E II: Form E II
F: Form F
H: Form H
Enter the total amount of the purchase order voucher for the selected form type.
22.7 Entering Direct Expenses
This section provides an overview of direct expenses and discusses how to:
  • Set the processing option for Direct Expense Entries (P75I2142).
  • Enter a direct expense.
22.7.1 Understanding Direct Expenses
Use the Direct Expense Entries program (P75I2142) to enter the direct expenses incurred for capital goods, goods used for personal consumption, and stock transfers for a specific month, year, and business unit. The system calculates the total amount of direct expenses incurred.
Direct expenses do not require a purchase order.
22.7.2 Forms Used to Enter Direct Expenses
Setoff for Selected Period W75I2142A Purchase tax (G75I2212), Direct Expense Entries Review the direct expenses for capital goods, personal consumption, and stock transfer for a specific period.
Work with Claims for Selected Period W75I2142D On the Setoff for Selected Period form, click Add. Enter the direct expense incurred for capital goods, personal consumption, and stock transfer for a specific period.
22.7.3 Setting the Processing Option for Direct Expense Entries (P75I2142)
22.7.3.1 Display
0 = Monthly, 1 = Quarterly, 2 = Yearly
Specify the reporting period for which the expense amount is calculated. Values are:
0: Monthly
1: Quarterly
2: Yearly
22.7.4 Entering a Direct Expense
Access the Work with Claims for Selected Period form.
For Capital Goods
Enter the amount incurred for capital goods.
On Personal Consumption
Enter the amount incurred on goods for personal consumption.
For Transferred Stock Advance
Enter the amount incurred on transferred goods.
General Set Off
Enter the expense amount incurred for other purposes.
22.8 Setup Requirements for Purchase Tax for Transactions
This table lists setup requirements for purchase tax for transactions in India:
Setup Requirements Comments
Assign form types to purchase vouchers for an interstate purchase. Use the Purchase CST Update program (P75I2131) to select the records for interstate purchases and assign concession form types to purchase vouchers.
Enter the form details for purchase vouchers. Use the Form Entry program (P75I2132) to enter the form details, such as form number, form date, and state of origin for the form type that is attached to a voucher. After the purchase tax update, you can enter the form details for the vouchers of the selected form type.
Print a list of purchase orders that are applicable for VAT. Use the VAT- Purchase Update program (R75I210) to print a list of purchase orders that are applicable for VAT for a specific date range.
Update purchase orders in India. After you generate a purchase order, you use the Purchase Order Receiver Tag File - IND - 43 program (P75I008) to enter required information about the manufacturer or importer, such as the manufacturer or importer number, invoice number, and invoice date.
Update purchase taxes for purchase vouchers. To update the purchase tax that is applicable for a supplier, assign a form type code to the purchase voucher using the Purchase Tax Update program (P75I4131).
Enter direct expenses. Use the Direct Expense Entries program (P75I2142) to enter the direct expenses incurred for capital goods, goods used for personal consumption, and stock transfers for a specific month, year, and business unit.
