This chapter includes these topics:
Section 15.1, "Work Order - Supplier Recovery Claim Overview"
Section 15.2, "Work Order - Supplier Recovery Claim Batch Import Programs"
Section 15.3, "Work Order - Supplier Recovery Claim Export Programs"
This chapter provides detailed information about the business interfaces that are available for the Work Order - Supplier Recovery Claim business object.
This table lists all of the available interface components:
| Interface Type | Available Interfaces |
| Batch Import Programs | This list includes the batch import programs for the Work Order - Supplier Recovery Claim business object: |
| Batch Export Programs | This list includes the batch export programs for the Work Order - Supplier Recovery Claim business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the available batch import programs that are associated with the Work Order - Supplier Recovery Claim business object:
You use batch export programs to retrieve and format data from the JD Edwards EnterpriseOne database so that it can be used by an external software system.
This table lists and describes the available batch export programs that are associated with the Work Order - Supplier Recovery Claim business object:
