40 Competency
This chapter includes these topics:
40.1 Competency Overview
This chapter provides detailed information about the business interfaces that are available for the Competency business object.
This table lists all of the available interface components:
Interface Type Available Interfaces
Real-Time Events This list includes the real-time events for the Competency business object:
  • RTCPOUT, which is a container event for RTCPOUTB.
You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components."
40.2 Competency Real-Time Events
This section describes the available real-time events associated with the Competency business object, which include:
40.2.1 RTCPOUT
RTCPOUTB is a real-time event notification used by JD Edwards EnterpriseOne to notify external systems of changes to competency master records (F05104).
Event Type Event Description Event Category Event Aggregate Product Code
RTCPOUT Competency Master RTE Container
Container event for RTCPOUTB (D0500870B ).
05
Conceptual Approach
When a user adds, modifies, or deletes competency master data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. The container event RTCPOUT contains one single event RTCPOUTB.
Objects that Can Initiate the Event
These objects can initiate the RTCPOUT event:
  • F05104 - Competency Master
  • P05104 - Competency Master
40.2.1.1 RTCPOUTB
Event Type Event Description Event Category Event Aggregate Product Code Data Structure Event Relationship
RTCPOUTB Competency Details RTE Single 05 D0500870B: Competency Real Time Event Notification Structure B Included in container event RTCPOUT.
Conceptual Approach
When a user adds, modifies, or deletes competency master data from the JD Edwards EnterpriseOne Human Resources system, the system publishes an event. The container event RTCPOUT contains one single event RTCPOUTB. The RTCPOUTB event contains all columns from the modified competency master record (F05104) and an action code specifying what action was performed on the data (added, changed, deleted).
