This chapter discusses these topics:
Section 51.1, "Purchase Order - Homebuilder Extensions Overview"
Section 51.2, "Purchase Order - Homebuilder Extensions Real-Time Events"
This chapter provides detailed information about the business interfaces that are available for the Purchase Order - Homebuilder Extensions business object.
This table lists all of the available interface components:
Interface Type | Available Interfaces |
Real-Time Events | This list includes the real-time events for the Purchase Order - Homebuilder business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This section describes the available real-time events associated with the Purchase Order - Homebuilder Extensions business object, which include:
Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
RTHBCOMMIT | HB Encumbrance Commitment | RTE | Single | 44H | D44H9904D | Included in container event . |
Conceptual Approach
As commitments are created in the J D Edwards Enterprise One, notification of those commitments is sent to the third party system where the system treats them as tasks that must be completed. For normal commitments (a vendor is specified), the Homebuilder management system first sends out commitments when they are posted by R44H7113 to the procurement system. Commitments for TBD vendors are sent to the third party system when they are generated to the lot start work file (F44H711) by R44H700.
Objects That Can Initiate the Event
These objects can initiate the event:
N44H0088 - F44H73W1 - Create HomeBuilder
N44H0113 – Lot Start Workfile Status Code
R44H700 – Lot Start Workfile Generation
