49 Construction Lot Master
This chapter includes these topics:
49.1 Construction Lot Master Overview
This chapter provides detailed information about the business interfaces that are available for the Construction Lot Master business object.
This table lists all of the available interface components:
Interface Type Available Interfaces
Real-Time Events This list includes the real-time events for the Construction Lot Master business object:
  • RTHBLMOUT, which is a container event for these single events:
    • RTHBLMHDR
    • RTHBLMBPH
    • RTHBLMBEA
You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components."
49.2 Construction Lot Master Real-Time Events
This section describes the available real-time events associated with the Construction Lot Master business object, which include:
    • RTHBLMHDR
    • RTHBLMBPH
    • RTHBLMBEA
49.2.1 RTHBLMOUT
RTHBLMOUT is used by JD Edwards EnterpriseOne to inform or notify third-party systems when Lot information or sales information has been added or changed in order to keep the two systems synchronized.
Event Type Event Description Event Category Event Aggregate Product Code
RTHBLMOUT Home Builder Lot Master RTE Container
Container event for:
  • RTHBLMHDR
  • RTHBLMBPH
  • RTHBLMBEA
44H
Conceptual Approach
Lot master and related information on a buyer (if one exists) is sent to a third party after the point in time that the lot is released for construction. Trigger points: at generation of lot work file; at lot master maintenance if work file has already been generated; at sales master maintenance if plan/elevation changes.
Objects That Can Initiate the Event
These objects can initiate the container event, and the events contained within it:
  • N44H0083 – Home Builder Activity Rule Interface
  • P44H201 – Lot Master
  • P44H500 – Sales Management
  • R44H700 – Lot Start Workfile Generation
49.2.1.1 RTHBLMHDR
RTHBLMHDR is used by JD Edwards Enterprise One to inform or notify third-party systems when Lot information or sales information has been added or changed in order to keep the two systems synchronized.
Event Type Event Description Event Category Event Aggregate Product Code Data Structure Event Relationship
RTHBLMHDR HB Lot Master Buyer Header RTE Single 44H D44H9903D Included in container event RTHBLMOUT.
Conceptual Approach
49.2.1.2 RTHBLMBPH
RTHBLMBPH is used by EnterpriseOne Homebuilder to inform or notify third-party systems when Lot information or sales information has been added or changed in order to keep the two systems synchronized. This single event holds information about lot phone number.
RTHBLMBPH HB Lot Master Buyer Phones RTE Single 44H D44H9903E Included in container event RTHBLMOUT.
Conceptual Approach
Lot master and related information on a buyer (if one exists) is sent to a third party after the point in time that the lot is released for construction. Trigger points occur at generation of lot work file; at lot master maintenance if work file has already been generated; at sales master maintenance if plan/elevation changes.
49.2.1.3 RTHBLMBEA
RTHBLMBEA is used by EnterpriseOne Homebuilder to inform or notify third-party systems when Lot information or sales information has been added or changed in order to keep the two systems synchronized. This single event holds information about lot email address.
RTHBLMBEA HB Lot Master Buyer Address RTE Single 44H D44H9903F Included in container event RTHBLMOUT.
Conceptual Approach
