This chapter includes these topics:
This chapter provides detailed information about the business interface components that are available for the Work Order - Food and Beverage business object.
This table lists all of the additional interface components:
| Interface Type | Available Interfaces |
| Batch Import Programs | This list includes the batch import programs for the Work Order - Food and Beverage business object: |
| Orchestration (Release 9.1 Update) | Add Blend Operation
For additional information about the Add Blend Operation orchestration, see Section 7.1.5, "Add Blend Operation". |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
You use batch import programs to import data from an external software system into the JD Edwards EnterpriseOne system, where it can then be processed by EnterpriseOne programs.
This table lists and describes the Work Order - Food and Beverage batch import programs that are available:
