This chapter includes these topics:
This chapter provides detailed information about the business interfaces that are available for the Work Order - Equipment business object.
This table lists all of the available interface components:
Interface Type | Available Interfaces |
Business Services | These are the published business services available for the Work Order - Equipment business object: |
Real-Time Events | This list includes the real-time events for the Work Order - Equipment business object: |
Note: You can find additional technical information about each type of business interface component. For additional descriptions of the information available, and instructions for finding this information, see Chapter 5, "Accessing Additional Information for Business Interface Components." |
This published business service processes equipment work order information using these business services:
These business services are documented under the Work Order Processor published business service, as they are also managed by that service. See Section 78.3.1, "Work Order Processor (J4800010)" and Section 78.3.2, "Work Order Query Processor (J4800020)."
This section describes the available real-time events associated with the Work Order business unit, which include:
RTEQORDOUT is a container event that is generated by the JD Edwards EnterpriseOne system to provide work order information.
Event Type | Event Description | Event Category | Event Aggregate | Product Code |
RTEQORDOUT | Equipment Order | RTE | Contains the RTEQORDHDR (D1702960 ) event. | H13 |
Conceptual Approach
A work order record added, modified or deleted in the JD Edwards EnterpriseOne system creates, modifies, or deletes a record in the Work Order Master File table (F4801) and the Work Order Master Tag File table (F4801T).
Objects That Can Initiate The Event
The X4801 - X4801 Work Order Entry Master business function can initiate the RTEQORDOUT event, and the single event contained within the event.
RTEQORDHDR is a single event that is generated by the JD Edwards EnterpriseOne system to provide work order information.
Event Type | Event Description | Event Category | Event Aggregate | Product Code | Data Structure | Event Relationship |
RTEQORDHDR | Equipment Order Header | RTE | Single | H13 | D1702960: Equipment Order Real Time Template | Included in container event RTEQORDOUT. |
Conceptual Approach
