This chapter contains the following topics:
Section 1.1, "JD Edwards EnterpriseOne Rental Management Overview"
Section 1.2, "JD Edwards EnterpriseOne Rental Management Business Process"
Section 1.3, "JD Edwards EnterpriseOne Rental Management Integrations"
Section 1.4, "JD Edwards EnterpriseOne Rental Management Implementation"
JD Edwards EnterpriseOne Rental Management enables a company to manage the rental and sale of items, including capital equipment, inventory items, and associated services. You can manage all aspects of a rental service, including:
Managing rental contracts and agreements
Handling equipment and item commitments to inventory
Billing (periodic)
Managing rental cost allocations
Managing asset depreciation expense
Managing the movement of assets in and out of inventory as they are rented out and returned, and serviced at the end of the rental contract
Reporting for rental contracts, including profitability
This process flow illustrates the standard JD Edwards EnterpriseOne Rental Management business process:
Figure 1-1 Rental Management Business Process
The JD Edwards EnterpriseOne Rental Management process flow includes the following steps:
Set up constants, actions, rental line types, and rental item details. You set up these features within the Rental Management system.
You also set up address book records, inventory, asset (equipment), routing, and work orders information that you use for the rental contract.
Set up the contract. In the contract header, you set up customer numbers, contract dates, reservation, delivery, and invoice information. In the contract detail, you set up information about individual lines, such as rental item information, type of inventory commitment, billing, and tax information. The system saves the contract header information in the Rental Contract Header table (F54R10), and the contract detail information in the Rental Contract Detail table (F54R11).
After a rental item is linked to a contract, you can use the rental item workbench to review information about the item quantity, item status, and the contracts associated with the rental item.
Review updates to the F54R10 and F54R11 table through the rental contract ledger.
Generate related orders (sales order, service order, and purchase order) to process and track the rental contract. You can generate related orders through interactive programs or through a batch program.
Alternately, you can manually link to the rental contract the one-off sales orders, service orders, or purchase orders that you created outside the Rental Management system.
Generate periodic rental billing for the rental contract.
For sales order, generate the invoice through the sales order system. You can track and review shipment information of a rental contract sales order from within the Rental Management system.
For work order, one-off sales order, and periodic service billing, you generate the billing through the JD Edwards EnterpriseOne Contract and Service Billing system.
Process the return of items back to the inventory by generating a return inbound purchase order. After you receive the purchase order, the items follow the receipt routing process where they are directly moved to stock (inventory), reworked, rejected, or scrapped. You generate a service order for items that must be reworked before they can be moved to the inventory. You generate a sales order for items that are rejected, and if the customer is liable for any damages to the items.
You can review and inquire about transactions associated with partial returns and dispositions. You can generate the Unrecognized Revenue report to calculate the rental revenue that is not included in the billing period. You use this report to record as much profit as possible in the company's income statements.You can generate the Rental Item Cost Calculation report to calculate the extended cost of the rental contract for a non-serialized item, and the Asset Depreciation Allocation report to move the depreciation expense from the rental centre (business unit) to the business unit that has rented the asset.
The JD Edwards EnterpriseOne Rental Management system integrates with these JD Edwards EnterpriseOne products:
JD Edwards EnterpriseOne Address Book
JD Edwards EnterpriseOne Accounts Receivable
JD Edwards EnterpriseOne Accounts Payable
JD Edwards EnterpriseOne General Accounting
JD Edwards EnterpriseOne Fixed Assets
JD Edwards EnterpriseOne Capital Asset Management
JD Edwards EnterpriseOne Work Orders
JD Edwards EnterpriseOne Service Billing
JD Edwards EnterpriseOne Inventory Management
JD Edwards EnterpriseOne Sales Order Management
JD Edwards EnterpriseOne Procurement
This section provides an overview of the steps that are required to implement JD Edwards EnterpriseOne Rental Management.
In the planning phase of the implementation, take advantage of all JD Edwards EnterpriseOne sources of information, including the installation guides and troubleshooting information.
When determining which electronic software updates (ESUs) to install for JD Edwards EnterpriseOne Rental Management, use the EnterpriseOne and World Change Assistant. EnterpriseOne and World Change Assistant, a Java-based tool, reduces the time required to search and download ESUs by 75 percent or more, and enables you to install multiple ESUs at one time.
See JD Edwards EnterpriseOne Tools Software Updates Guide.
For information about the Oracle Business Accelerator solution for implementation of JD Edwards EnterpriseOne Rental Management, review the documentation available.
See http://docs.oracle.com/cd/E24705_01/index.htm
The suggested global implementation steps for JD Edwards EnterpriseOne Rental Management are:
Set up global user-defined codes.
Set up companies, fiscal date patterns, and business units.
Set up next numbers.
Set up accounts and the chart of accounts.
Set up the General Accounting constants.
Set up multicurrency processing, including currency codes and exchange rates.
Set up ledger type rules.
Set up customers in the Address Book.
Set up the customer in the Customer Master by Line of Business.
Set up inventory information, such as branch/plant constants, default locations and printers, manufacturing and distribution AAIs, and document types.
Set up branch/plants.
Set up line types.
Set up lots.
These are the suggested application-specific implementation steps for JD Edwards EnterpriseOne Rental Management:
Set up Rental Management constants, actions, rental line types, and rental item details.
See Setting Up the JD Edwards EnterpriseOne Rental Management System.
Set up rental contracts.
Set up AAIs.
