Chapter 35. Upgrading Berkeley DB 3.1 applications to Berkeley DB 3.2
Table of Contents
Release 3.2: introduction
Release 3.2: DB_ENV->set_flags
Release 3.2: DB callback functions, app_private field
Release 3.2: Logically renumbering records
Release 3.2: DB_INCOMPLETE
Release 3.2: DB_ENV->set_tx_recover
Release 3.2: DB_ENV->set_mutexlocks
Release 3.2: Java and C++ object reuse
Release 3.2: Java java.io.FileNotFoundException
Release 3.2: db_dump
Release 3.2: Upgrade Requirements
The following pages describe how to upgrade applications coded against the Berkeley DB 3.1 release interfaces to the Berkeley DB 3.2 release interfaces. This information does not describe how to upgrade Berkeley DB 1.85 release applications.
