A replication group is a collection of two or more database environments which are configured to replicate with one another. When operating normally, a replication group consists of a master site and one or more read-only sites.
For Replication Manager applications, the sites comprising the replication group are recorded in an internal group membership database, so even if a group member is not available, it counts towards the group's total site count. This matters for certain replication activities, such as holding elections and acknowledging replication messages that require some number of sites to participate in these activities. Replicated applications will often require all sites, or a majority of sites, to participate before the activity can be completed.
If you are configuring your application to keep replication metadata in-memory by specifying the DB_REP_CONF_INMEM flag to the DB_ENV->rep_set_config() method, then the internal group membership database is not stored persistently on disk. This severely limits Replication Manager's ability to automatically manage group membership. For more information, including some work-arounds, see Managing replication directories and files.
Because Replication Manager tracks group members, there are some administrative activities that you should know about when using Berkeley DB replication.
To add a site to a replication group, you merely start up the site such that it knows where at least one site in the group is located. The new site then joins the group. When this happens, the new site is recorded in the group membership database.
Note that when you are starting the very first site in the group for the very first time (called the primordial start up), there are no other existing sites to help the new site join the group. In fact, a primordial start up actually creates the group. For this reason, there are some slight differences on how to perform a primordial start up. For a description of this, see Primordial startups.
When you add a site to a replication group, you use the following general procedure:
Make sure your replication group is operating well enough that write activity can occur.
Create and open the environment such that it is configured to use replication.
Use DB_ENV->repmgr_site() to obtain a DB_SITE handle.
Configure this handle for the local site's host
and port information when you create the handle.
Then, use DB_SITE->set_config() to indicate that
this is the local site by setting the
DB_LOCAL_SITE
parameter.
Use DB_ENV->repmgr_site() to obtain a second DB_SITE
handle. Configure this handle with the host and
port information for a site that already belongs
to the replication group. Then, use
DB_SITE->set_config() to indicate this site is a
"helper" site by setting the
DB_BOOTSTRAP_HELPER
parameter. By configuring a DB_SITE handle in
this way, your new site will know how to contact
the replication group so that it can join the
group.
Start replication as normal by configuring an acknowledgement policy, setting the site's replication priority, and then calling DB_ENV->repmgr_start().
Note that on subsequent start-ups of your replication code, any helper site information you might provide is ignored because the Replication Manager reads the group membership database in order to obtain this information.
Also, be aware that if the new site cannot be added to
the group for some reason (because a master site is not
available, or because insufficient replicas are running to
acknowledge the new site), the attempt to start the new
site via DB_ENV->repmgr_start() will fail and return
DB_REP_UNAVAIL
. You can then pause
and retry the start up attempt until it completes
successfully.
You must use the exact same host string and port number to refer to a given site throughout your application and on each of its sites.
Elections and message acknowledgements require knowledge of the total number of sites in the group. If a site is shut down, or is otherwise unable to communicate with the rest of the group, it still counts towards the total number of sites in the group. In most cases, this is the desirable behavior.
However, if you are shutting down a site permanently, then you should remove that site from the group. You might also want to remove a site from the group if you are shutting it down temporarily, but nevertheless for a very long period of time (days or weeks). In either case, you remove a site from the group by:
On one of the sites in your replication group (this does not have to be the master site), use DB_ENV->repmgr_site() to obtain a DB_SITE handle. Configure this handle with the host and port information of the site that you want to remove.
Note that this step can occur at any site — including the site that you are removing from the group.
Call the DB_SITE->remove() method. This removes the identified site from the group membership database. If this action is not performed on the master site, the client sends a request to the master to perform the operation and awaits confirmation.
A client removing itself can close its database environment any time after the DB_SITE->remove() method returns. A site that has been removed by another site can close its database environment any time after the DB_EVENT_REP_LOCAL_SITE_REMOVED event is fired.
Upon completing the above procedure, DO NOT call the DB_SITE->close() method. After removing (or even attempting to remove) a site from the group using a DB_SITE handle, the handle must never be accessed again.
If you have never started a site in a replication group before, then the group membership database does not exist. In this situation, you must start an initial site and declare it to be the group creator. This causes the site to become the master, create the group membership database, and create a replication group of size 1. After that, subsequent sites can add themselves to the group as described in Adding sites to a replication group.
It is never incorrect to declare a site the group creator. This is true even well-after the replication group has been established. This is because group creator information is ignored on any site start-up, except for the primoridial start-up; that is, a start-up where the group membership database does not exist.
To declare a site as the group creator:
this is the group creator site by setting the
DB_GROUP_CREATOR
parameter.
Start replication as normal by configuring acknowledgement policies, setting replication priorities for the site, and then calling DB_ENV->repmgr_start().
Prior to the Berkeley DB 11.2.5.2 release, replication group membership was managed differently than in the way it is described in the previous sections. For this reason, when you upgrade from older releases of Berkeley DB to 11.2.5.2 or later, the upgrade procedure is different than when upgrading between other releases.
To perform an upgrade that takes you from the old way of managing group membership to the new way of managing group membership (pre-11.2.5.2 to 11.2.5.2 and later), do the following:
Update your replication code to use the new DB_SITE handle and related methods. Recompile and thoroughly test your code to make sure it is production-ready.
Do the following one production machine at a time. Make sure to do this at the master site LAST.
Shut down the old replication code.
Install the new replication code.
Configure a DB_SITE handle for the
local site. Use DB_SITE->set_config() to
indicate that this is a legacy site by
setting the DB_LEGACY
parameter.
every other site
in the replication group. Set the
DB_LEGACY
parameter
for each of these handles.
Please pay careful attention to this step. To repeat: a DB_SITE handle MUST be configured for EVERY site in the replication group.
Start replication. The site is upgraded at this point.
Once you have performed this procedure for each production site, making sure to upgrade the master only after every other site has been upgraded, you are done upgrading your replicated application to use the current group membership mechanism.
On subsequent restarts of your replication code, you do
not need to specify the DB_LEGACY
parameter, nor do you need to identify all of the
replication group members. However, it is not an error if
you do specify this information on subsequent start ups.
