The various sites comprising a replication group frequently need to communicate with one another. Mostly, these messages are handled for you internally by the Replication Manager. However, your application may have a requirement to pass messages beyond what the Replication Manager requires in order to satisfy its own internal workings.
For this reason, you can access and use the Replication
Manager's internal message channels. You do this by using the
DB_CHANNEL
class, and by implementing a
message handling function on each of your sites.
Note that an example of using Replication Manager message channels is available in the distribution. See Ex_rep_chan: a Replication Manager channel example for more information.
The DB_CHANNEL
class provides a
series of methods which allow you to send messages to the
other sites in your replication group. You create a
DB_CHANNEL
handle using the
DB_ENV->repmgr_channel() method. When you are done with the
handle, close it using the DB_CHANNEL->close() method. A
closed handle must never be accessed again. Note that all
channel handles should be closed before the associated
environment handle is closed. Also, allow all message
operations to complete on the channel before closing the
handle.
When you create a DB_CHANNEL
handle,
you indicate what channel you want to use. Possibilities
are:
The numerical env ID of a remote site in the replication group.
DB_EID_MASTER
Messages sent on this channel are sent only to the master site. Note that messages are always sent to the current master, even if the master has changed since the channel was opened.
If the local site is the master, then sending messages on this channel will result in the local site receiving those messages echoed back to itself.
You can send any message you want over a message channel. The message can be as simple as a character string and as complex as a large data structure. However, before you can send the message, you must encapsulate it within one or more DBTs. This means marshaling the message if it is contained within a complex data structure.
The methods that you use to send messages all accept an array of DBTs. This means that in most circumstances it is perfectly acceptable to send multi-part messages.
Messages may be sent either asynchronously or synchronously. To send a message asynchronously, use the DB_CHANNEL->send_msg() method. This method sends its message and then immediately returns without waiting for any sort of a response.
To send a message synchronously, use the DB_CHANNEL->send_request() method. This method blocks until it receives a response from the site to which it sent the message (or until a timeout threshold is reached).
Message responses are required if a message is sent on a channel using the DB_CHANNEL->send_request() method. That method accepts the address of a single DBT which is used to receive the response from the remote site.
Message responses are encapsulated in a single DBT. The response can be anything from a complex data structure, to a string, to a simple type, to no information at all. In the latter case, receipt of the DBT is sufficient to indicate that the request was received at the remote site.
Responses are sent back from the remote system using its message handling function. Usually that function calls DB_CHANNEL->send_msg() to send a single response.
The response must be contained in a single DBT. If a multi-part response is required by the application, you can configure the response DBT that you provide to DB_CHANNEL->send_request() for bulk operations.
Messages received at a remote site are handled using a callback function. This function is configured for the local environment using the DB_ENV->repmgr_msg_dispatch() method. For best results, the message dispatch function should be configured for the local environment before replication is started. In this way, you do not run the risk of missing messages sent after replication has started but before the message dispatch function is configured for the environment.
The callback configured by DB_ENV->repmgr_msg_dispatch() accepts four parameters of note:
A response channel. This is the channel the function will use to respond to the message, if a response is required. To respond to the message, the function uses the DB_CHANNEL->send_msg() method.
An array of DBTs. These hold the message that this function must handle.
A numerical value that indicates how many elements the previously described array holds.
A flag that indicates whether the message
requires a response. If the flag is set to
DB_REPMGR_NEED_RESPONSE
then the function should send a single DBT in
response using the channel provided to this
function, and the DB_CHANNEL->send_msg() method.
For an example of using this callback, see the
operation_dispatch()
function,
which is available with the
ex_rep_chan example in your product
distribution.
