When using dbstl, make sure memory allocated in the heap is released after use. The rules for this are:
dbstl will free/delete any memory allocated by dbstl itself.
You are responsible for freeing/deleting any memory allocated by your code outside of dbstl.
                When you open a DbEnv or
                Db object using
                dbstl::open_env() or
                dbstl::open_db(), you do
                not need to delete that object. However, if you new'd
                that object and then opened it without using the
                dbstl::open_db() methods,
                you are responsible for deleting the object.
                Note that you must new the
                Db or
                DbEnv object, which
                allocates it on the heap. You can not allocate it on
                the stack. If you do, the order of destruction is
                uncontrollable, which makes dbstl unable to work
                properly.
                You can call dbstl_exit()
                before the process exits, to release any memory
                allocated by dbstl that has to live during the entire
                process lifetime. Releasing the memory explicitly will
                not make much difference, because the process is about
                to exit and so all memory allocated on the heap is
                going to be returned to the operating system anyway.
                The only real difference is that your memory leak
                checker will not report false memory leaks.
                dbstl_exit() releases any memory
                allocated by dbstl on the heap. It also performs other
                required shutdown operations, such as closing any
                databases and environments registered to dbstl and
                shared across the process.
                If you are calling the
                dbstl_exit() function, and
                your DbEnv or
                Db objects are new'd by
                your code, the dbstl_exit()
                function should be called before deleting the
                DbEnv or
                Db objects, because they
                need to be closed before being deleted. Alternatively,
                you can call the
                dbstl::close_env() or
                dbstl::close_db()
                functions before deleting the
                DbEnv or
                Db objects in order to
                explicitly close the databases or environments. If you
                do this, can then delete these objects, and then call
                dbstl_exit().
                In addition, before exiting a thread that uses
                dbstl API, you can call the
                dbstl_thread_exit() function
                to release any Berkeley DB handles if they are not
                used by other threads. If you do not call the
                or call this function only in some threads, all open
                Berkeley DB handles will be closed by the
                dbstl_exit()function. You
                must call the dbstl_exit()
                function before the process exits, to avoid
                memory leak and database update loss, if you do not
                have transactions and persistent log files.
                Only when you are storing raw bytes (such as a
                bitmap) do you have to store and retrieve data by
                using the DbstlDbt helper
                class. Although you also can do so simply by using the
                Berkeley DB Dbt class, the
                DbstlDbt class offers more
                convenient memory management behavior.
                When you are storing
                DbstlDbt objects (such as
                db_vector<DbstlDbt>),
                you must allocate heap memory
                explicitly using the malloc()
                function for the DbstlDbt
                object to reference, but you do not need to free the
                memory – it is automatically freed by the
                DbstlDbt object that owns
                it by calling the standard C library
                free() function.
                However, because dbstl supports storing any type of
                object or primitive data, it is rare that you would
                have to store data using
                DbstlDbt objects while
                using dbstl. Examples of storing
                DbstlDbt objects can be
                found in the
                StlAdvancedFeaturesExample::arbitrary_object_storage()
                and
                StlAdvancedFeaturesExample::char_star_string_storage()
                methods.
