Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Reference Manual     Oracle Solaris Cluster
search filter icon
search icon
Document Information
Preface
Introduction
OSC33 1
OSC33 1cl
OSC33 1ha
OSC33 1m
OSC33 3ha
scds_calls(3HA)
scds_close(3HA)
scds_error_string(3HA)
scds_error_string_i18n(3HA)
scds_failover_rg(3HA)
scds_fm_action(3HA)
scds_fm_net_connect(3HA)
scds_fm_net_disconnect(3HA)
scds_fm_print_probes(3HA)
scds_fm_sleep(3HA)
scds_fm_tcp_connect(3HA)
scds_fm_tcp_disconnect(3HA)
scds_fm_tcp_read(3HA)
scds_fm_tcp_write(3HA)
scds_free_ext_property(3HA)
scds_free_netaddr_list(3HA)
scds_free_net_list(3HA)
scds_free_port_list(3HA)
scds_get_current_method_name(3HA)
scds_get_ext_property(3HA)
scds_get_netaddr_list(3HA)
scds_get_port_list(3HA)
scds_get_resource_group_name(3HA)
scds_get_resource_name(3HA)
scds_get_resource_type_name(3HA)
scds_get_rg_hostnames(3HA)
scds_get_rg_hostnames_zone(3HA)
scds_get_rs_hostnames(3HA)
scds_get_zone_name(3HA)
scds_hasp_check(3HA)
scds_initialize(3HA)
scds_pmf_get_status(3HA)
scds_pmf_restart_fm(3HA)
scds_pmf_signal(3HA)
scds_pmf_start(3HA)
scds_pmf_start_env(3HA)
scds_pmf_stop(3HA)
scds_pmf_stop_monitoring(3HA)
scds_print_netaddr_list(3HA)
scds_print_net_list(3HA)
scds_print_port_list(3HA)
scds_property_functions(3HA)
scds_restart_resource(3HA)
scds_restart_rg(3HA)
scds_simple_net_probe(3HA)
scds_simple_probe(3HA)
scds_svc_wait(3HA)
scds_syslog(3HA)
scds_syslog_debug(3HA)
scds_timerun(3HA)
scha_calls(3HA)
scha_cluster_close(3HA)
scha_cluster_get(3HA)
scha_cluster_getlogfacility(3HA)
scha_cluster_getnodename(3HA)
scha_cluster_get_zone(3HA)
scha_cluster_getzone(3HA)
scha_cluster_open(3HA)
scha_cluster_open_zone(3HA)
scha_control(3HA)
scha_control_zone(3HA)
scha_resource_close(3HA)
scha_resource_get(3HA)
scha_resource_get_zone(3HA)
scha_resourcegroup_close(3HA)
scha_resourcegroup_get(3HA)
scha_resourcegroup_get_zone(3HA)
scha_resourcegroup_open(3HA)
scha_resourcegroup_open_zone(3HA)
scha_resource_open(3HA)
scha_resource_open_zone(3HA)
scha_resource_setstatus(3HA)
scha_resource_setstatus_zone(3HA)
scha_resourcetype_close(3HA)
scha_resourcetype_get(3HA)
scha_resourcetype_get_zone(3HA)
scha_resourcetype_open(3HA)
scha_resourcetype_open_zone(3HA)
scha_strerror(3HA)
scha_strerror_i18n(3HA)
OSC33 4
OSC33 5
OSC33 5cl
OSC33 7
OSC33 7p
Index
scds_fm_tcp_read
- read data using a TCP connection to an application
Synopsis
cc [flags…] -I /usr/cluster/include file -L /usr/cluster/lib -l dsdev
#include <rgm/libdsdev.h>
scha_err_t scds_fm_tcp_read(scds_handle_t  handle, int sock, char *buffer,
     size_t *size, time_t timeout);
Description
The scds_fm_tcp_read() function reads data from a TCP connection with a process being monitored.
The size argument is an input and argument. On input, you specify the size of the buffer, bytes. On completion, the function places the data in buffer and specifies the actual number of bytes read in size. If the buffer is not big enough for the number of bytes read, the function returns a full buffer of size bytes, and you can call the function again for further data.
If the function times out, it returns SCHA_ERR_TIMEOUT. In this case, the function might return fewer bytes than requested, indicated by the value returned in size.
Parameters
The following parameters are supported:
handle
The handle returned from scds_initialize(3HA).
sock
The socket number returned by a previous call to scds_fm_tcp_connect(3HA).
buffer
Data buffer.
size
Data buffer size. On input, you specify the size of the buffer, in bytes. On output, the function returns the actual number of bytes read.
timeout
Timeout value in seconds.
Return Values
The scds_fm_tcp_read() function returns the following:
0
The function succeeded.
nonzero
The function failed.
Errors
SCHA_ERR_NOERR
Indicates that the function succeeded.
SCHA_ERR_TIMEOUT
Indicates that the function timed out.
Other values
Indicate that the function failed. See scha_calls(3HA) for the meaning of failure codes.
Files
/usr/cluster/include/rgm/libdsdev.h
Include file
/usr/cluster/lib/libdsdev.so
Library
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
SUNWscdev
Interface Stability
Evolving
See Also
scds_fm_tcp_disconnect(3HA), scds_fm_tcp_write(3HA), scds_initialize(3HA), scha_calls(3HA), attributes(5)
