Skip Navigation Links
Exit Print View
Oracle Solaris Cluster Reference Manual     Oracle Solaris Cluster
search filter icon
search icon
Document Information
Preface
Introduction
OSC33 1
OSC33 1cl
OSC33 1ha
OSC33 1m
OSC33 3ha
scds_calls(3HA)
scds_close(3HA)
scds_error_string(3HA)
scds_error_string_i18n(3HA)
scds_failover_rg(3HA)
scds_fm_action(3HA)
scds_fm_net_connect(3HA)
scds_fm_net_disconnect(3HA)
scds_fm_print_probes(3HA)
scds_fm_sleep(3HA)
scds_fm_tcp_connect(3HA)
scds_fm_tcp_disconnect(3HA)
scds_fm_tcp_read(3HA)
scds_fm_tcp_write(3HA)
scds_free_ext_property(3HA)
scds_free_netaddr_list(3HA)
scds_free_net_list(3HA)
scds_free_port_list(3HA)
scds_get_current_method_name(3HA)
scds_get_ext_property(3HA)
scds_get_netaddr_list(3HA)
scds_get_port_list(3HA)
scds_get_resource_group_name(3HA)
scds_get_resource_name(3HA)
scds_get_resource_type_name(3HA)
scds_get_rg_hostnames(3HA)
scds_get_rg_hostnames_zone(3HA)
scds_get_rs_hostnames(3HA)
scds_get_zone_name(3HA)
scds_hasp_check(3HA)
scds_initialize(3HA)
scds_pmf_get_status(3HA)
scds_pmf_restart_fm(3HA)
scds_pmf_signal(3HA)
scds_pmf_start(3HA)
scds_pmf_start_env(3HA)
scds_pmf_stop(3HA)
scds_pmf_stop_monitoring(3HA)
scds_print_netaddr_list(3HA)
scds_print_net_list(3HA)
scds_print_port_list(3HA)
scds_property_functions(3HA)
scds_restart_resource(3HA)
scds_restart_rg(3HA)
scds_simple_net_probe(3HA)
scds_simple_probe(3HA)
scds_svc_wait(3HA)
scds_syslog(3HA)
scds_syslog_debug(3HA)
scds_timerun(3HA)
scha_calls(3HA)
scha_cluster_close(3HA)
scha_cluster_get(3HA)
scha_cluster_getlogfacility(3HA)
scha_cluster_getnodename(3HA)
scha_cluster_get_zone(3HA)
scha_cluster_getzone(3HA)
scha_cluster_open(3HA)
scha_cluster_open_zone(3HA)
scha_control(3HA)
scha_control_zone(3HA)
scha_resource_close(3HA)
scha_resource_get(3HA)
scha_resource_get_zone(3HA)
scha_resourcegroup_close(3HA)
scha_resourcegroup_get(3HA)
scha_resourcegroup_get_zone(3HA)
scha_resourcegroup_open(3HA)
scha_resourcegroup_open_zone(3HA)
scha_resource_open(3HA)
scha_resource_open_zone(3HA)
scha_resource_setstatus(3HA)
scha_resource_setstatus_zone(3HA)
scha_resourcetype_close(3HA)
scha_resourcetype_get(3HA)
scha_resourcetype_get_zone(3HA)
scha_resourcetype_open(3HA)
scha_resourcetype_open_zone(3HA)
scha_strerror(3HA)
scha_strerror_i18n(3HA)
OSC33 4
OSC33 5
OSC33 5cl
OSC33 7
OSC33 7p
Index
scds_pmf_signal
- send a signal to a process tree under PMF control
Synopsis
cc [flags…] -I /usr/cluster/include file -L /usr/cluster/lib -l dsdev
#include <rgm/libdsdev.h>
scha_err_t scds_pmf_signal(scds_handle_t handle, scds_pmf_type_t program_type,
     int instance, int signal, time_t timeout);
Description
The scds_pmf_signal() function sends the specified signal to a process tree running under PMF control. This function is equivalent to the pmfadm(1M) command with the -k option.
After sending the signal, the scds_pmf_signal() function waits for the specified timeout period for the process tree to die, before returning. A value of 0 for timeout tells the function to return immediately without waiting for any process to exit. A value of -1 tells the function to wait indefinitely for the processes to exit.
Parameters
The following parameters are supported:
handle
The handle returned from scds_initialize()
program_type
Type of program to execute. Valid types are:
SCDS_PMF_TYPE_SVC
Data service application
SCDS_PMF_TYPE_MON
Fault monitor
SCDS_PMF_TYPE_OTHER
Other
instance
For resources with multiple instances, this integer, starting at 0, uniquely identifies the instance. For single instance resources, use 0.
signal
Solaris signal to send. See signal(3HEAD).
timeout
Timeout period in seconds.
Return Values
The scds_pmf_signal() function returns the following:
0
The function succeeded.
nonzero
The function failed.
Errors
SCHA_ERR_TIMEOUT
The process tree did not exit within the specified timeout period after the signal was sent.
SCHA_ERR_NOERR
Other values
Indicate the function failed. See scha_calls(3HA) for the meaning of failure codes.
Files
/usr/cluster/include/rgm/libdsdev.h
Include file
/usr/cluster/lib/libdsdev.so
Library
Attributes
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Availability
SUNWscdev
Interface Stability
Evolving
See Also
pmfadm(1M), scds_initialize(3HA), scha_calls(3HA), signal(3HEAD), attributes(5)
