C H A P T E R  7
Configure ILOM Firmware Settings Using SNMP
Topics
Description
Links
Review the prerequisites
Configuring ILOM firmware interfaces
Related Topics
For ILOM
Section
Guide
  • Concepts
  • Configuration Management and Firmware Updates
Oracle Integrated Lights Out Manager (ILOM) 3.0 Concepts Guide (820-6410)
  • Web
  • Updating ILOM Firmware
Oracle Integrated Lights Out Manager (ILOM) 3.0 Web Interface Procedures Guide (820-6411)
  • CLI
Oracle Integrated Lights Out Manager (ILOM) 3.0 CLI Procedures Guide (820-6412)
The ILOM 3.0 Documentation Collection is available at: http://docs.sun.com/app/docs/prod/int.lights.mgr30#hic
Before You Begin
Prior to performing the procedures in this chapter, you should ensure that the following requirements are met.
Note - The example SNMP commands presented in this section are based on the Net-SNMP sample applications and, therefore, will only work as presented if you have Net-SNMP and the Net-SNMP sample applications installed.
Configuring ILOM Firmware Interfaces
procedure icon  View and Configure ILOM Firmware Settings
Note - You can use the get and set commands to view and configure ILOM firmware settings. For a description of the MIB objects used in these commands, see the SUN-ILOM-CONTROL-MIB.
1. Log in to a host that has an SNMP tool and the ILOM MIBs installed. For example, type:
ssh username@snmp_manager_ipaddress
Password: password
2. Refer to the following SNMP command examples:
