Sun Management Center 3.6.1 User's Guide
ProcedureTo View Module Rules
  1. In the Details window, click the Module Manager tab.
  2. In the Modules with Load Status list, select the module of interest and click Rules.
    The Threshold Summary of Module screen is displayed, containing the name of the selected module after the colon (:). In this example, the Kernel Reader (Simple) module is shown.
    Figure 11–1 Threshold Summary of Module Screen
    Threshold Summary of Module window shows Kernel Reader
(Simple) module properties.
    A module rules window contains the following information:
    Attribute Name
    Identifies the data property.
    Rule Name
    Shows the rule name. If the rule is simple, the threshold value appears. If the rule is complex, a “-” appears. Click on the “-” to view threshold values in the Threshold list at the bottom of the window.
    Critical
    The most severe alarm state.
    Alert
    The mid-point alarm state.
    Caution
    The least severe alarm state.
    Rule Description
    Displays a rule description for the selected attribute.
    Thresholds
    Displays threshold values for the selected attribute.
    Parameter Description
    Describes the parameters that are shown in the Thresholds field.
  3. After you view the information, click Close to return to the Module status screen.
