You can choose a wide range of colors and fonts for your display either by using Style Manager or by customizing additional font and color resources. This chapter discusses how to customize fonts and color resources.
This chapter also describes how to specify style translations for DtEditor widget applications such as the desktop text editor (dtpad) and Mailer (dtmail), and alternates for DtEditor widget application menu accelerators that conflict with these translations.
Resources are used by applications to set certain aspects of appearance and behavior. For example, Style Manager (dtstyle) provides resources that enable you to specify where the system looks for files containing information about color palettes:
dtstyle*paletteDirectories: /usr/dt/palettes/C HomeDirectory/.dt/palettes
App-default files for the desktop applications are located in the /usr/dt/app-defaults/language directory.
Add the resources to the file /etc/dt/config/language/sys.resources. (You may have to create the file.)
For example, if in /etc/dt/config/C/sys.resources you specify:
AnApplication*resource: value
then the resource AnApplication*resource will be set in each user's RESOURCE_MANAGER property at the next login.
For more information about Style Manager resources, see the dtstyle man page. For more information about Mailer resources, see the dtmail man page.
Resources are loaded at session startup by Session Manager. For information on how Session Manager loads the resources into the RESOURCE_MANAGER, see Loading the Session Resources.
The following Process Manager Resources are available:
sampleNowTR
postPopupMenuTR
selectNextProcessTR
selectPrevProcessTR
selectFirstProcessTR
selectLastProcessTR
killSelectedProcessTR
By default UNIX bindings are not enabled.
The following procedure specifies:
EMACS style translations for DtEditor widget applications such as the desktop Text Editor (dtpad) and Mailer (dtmail)
Alternates for DtEditor widget application menu accelerators that conflict with these translations.
Add the following line to the HomeDirectory/.Xdefaults file:
#include "/usr/dt/app-defaults/language/UNIXbindings"
where language is the value of the LANG
environment variable.
Restart your session.
Insert the contents of the file /usr/dt/app-defaults/language/UNIXbindings into HomeDirectory/.Xdefaults.
Edit the bindings in the .Xdefaults file.
Restart your session when you have finished.
The /usr/dt/app-defaults/language/UNIXbindings file provides the bindings described in the tables below.
The Delete key deletes the previous character when the UNIX bindings are enabled, and Shift-Delete deletes the next character.
Table 17–1 lists the dtpad overrides for menu accelerators and accelerator text that conflict with the UNIX bindings.
Table 17–1 dtpad Overrides
Menu Accelerators and Accelerator Text |
Override |
Dtpad*fileMenu.print.acceleratorText: |
Dtpad*fileMenu.print.accelerator: |
Dtpad*editMenu.undo.acceleratorText: |
Ctrl+_ |
Dtpad*editMenu.undo.accelerator: |
Ctrl<Key>_ |
Dtpad*editMenu.paste.acceleratorText: |
Shift+Insert |
Dtpad*editMenu.paste.accelerator: |
Shift<Key>osfInsert |
Dtpad*editMenu.findChange.acceleratorText: |
Ctrl+S |
Dtpad*editMenu.findChange.accelerator: |
Ctrl<Key>s |
Table 17–2 lists the dtmail Compose window overrides for menu accelerators and accelerator text that conflict with the UNIX bindings.
Table 17–2 dtmail Compose Window Overrides
Override |
Dtmail*ComposeDialog*menubar*Edit.Undo.acceleratorText: |
Ctrl+_ |
Dtmail*ComposeDialog*menubar*Edit.Undo.accelerator: |
Ctrl<Key>_ |
Dtmail*ComposeDialog*menubar*Edit.Paste.acceleratorText: |
Shift+Insert |
Dtmail*ComposeDialog*menubar*Edit.Paste.accelerator: |
Dtmail*ComposeDialog*menubar*Edit.Find/Change.acceleratorText: |
Ctrl+S |
Dtmail*ComposeDialog*menubar*Edit.Find/Change.accelerator: |
Ctrl<Key>s |
The following translations provide (GNU style) EMACS control and Meta key bindings plus some additional bindings. When appropriate, they also allow the Shift key to be used in combination with the normal binding to reverse the direction of the operation. For example, Ctrl+Shift+F will move the cursor backward a character since Ctrl+F normally moves it forward a character.
The additional bindings are:
Ctrl+comma—backward-word
Ctrl+Shift+comma—forward-word
Ctrl+period—forward-word
Ctrl+Shift+period—backward-word
Ctrl+Return—end-of-file
Ctrl+Shift+Return—beginning-of-file
GNU EMACS binds delete-previous-character() rather than delete-next-character() to the Delete key. Meta+F is normally the mnemonic for the File menu, so the binding to forward-word() will be ignored. Use one of the other bindings for forward-word (for example, Ctrl+period).
Table 17–3 lists the DtEditor.text Translations
Table 17–3 DtEditor.text Translations
Modifier Key |
Key |
Action Routine |
c ~s |
<Key>a: |
beginning-of-line()\n\ |
c s |
<Key>a: |
end-of-line()\n\ |
c ~s |
<Key>b: |
backward-character()\n\ |
c s |
<Key>b: |
forward-character()\n\ |
c ~s |
<Key>b: |
c s |
<Key>b: |
backward-word()\n\ |
m ~s |
<Key>b: |
m s |
<Key>b: |
forward-word()\n\ |
c ~s |
<Key>d: |
delete-next-character()\n\ |
c s |
<Key>d: |
delete-previous-character()\n\ |
m ~s |
<Key>d: |
kill-next-word()\n\ |
m s |
<Key>d: |
kill-previous-word()\n\ |
c ~s |
<Key>e: |
end-of-line()\n\ |
c s |
<Key>e: |
c ~s |
<Key>f: |
c s |
<Key>f: |
m ~s |
<Key>f: |
forward-word()\n\ |
m s |
<Key>f: |
c |
<Key>j: |
newline-and-indent()\n\ |
c ~s |
<Key>k: |
kill-to-end-of-line()\n\ |
c s |
<Key>k: |
kill-to-start-of-line()\n\ |
c |
<Key>l: |
redraw-display()\n\ |
c |
<Key>m: |
newline()\n\ |
c s |
<Key>n: |
process-up()\n\ |
c ~s |
<Key>n: |
process-down()\n\ |
c |
<Key>o: |
newline-and-backup()\n\ |
c ~s |
<Key>p: |
process-up()\n\ |
c s |
<Key>p: |
process-down()\n\ |
c ~s |
<Key>u: |
c s |
<Key>u: |
c ~s |
<Key>v: |
next-page()\n\ |
c s |
<Key>v: |
previous-page()\n\ |
m ~s |
<Key>v: |
m s |
<Key>v: |
next-page()\n\ |
c |
<Key>w: |
kill-selection()\n\ |
c ~s |
<Key>y: |
unkill()\n\ |
m |
<Key>]: |
forward-paragraph()\n\ |
m |
<Key>[: |
backward-paragraph()\n\ |
c ~s |
<Key>comma: |
c s |
<Key>comma: |
forward-word()\n\ |
m |
<Key>\\<: |
beginning-of-file()\n\ |
c ~s |
<Key>period: |
forward-word()\n\ |
c s |
<Key>period: |
m |
<Key>\\>: |
end-of-file()\n\ |
c ~s |
<Key>Return: |
end-of-file()\n\ |
c s |
<Key>Return: |
~c ~s ~m ~a |
<Key>osfDelete: |
~c s ~m ~a |
<Key>osfDelete: |
delete-next-character() |
Using the Style Manager Font dialog box, you can select the font group and size you want for all applications. You can also specify fonts on the command line or use resources to:
Set font resources for individual applications
Assign different fonts to be used by the Font dialog box
A font is a type style in which text characters are printed or displayed. The desktop includes a variety of fonts in different styles and sizes.
A bitmap font is made from a matrix of dots. (By default, Style Manager configures bitmap fonts only.) The font is completely contained in one file. Many files are needed to have a complete range of sizes, slants, and weights.
Fonts are specified as values of resources and as parameters to commands. The X Logical Font Description (XLFD) name is the method by which a desired font is requested. The system finds the font that best matches the description it was given.
The Style Manager Font dialog box enables you to select fonts (up to seven sizes) for things such as text entry and labels. It also enables you to add or delete font groups.
When a font is selected, the following resources are written to the RESOURCE_MANAGER property:
SystemFont is used for system areas, such as menu bars, menu panes, push buttons, toggle buttons, and labels. The following resource is set by SystemFont:
*FontList
—displayed
in system areas of desktop clients and other clients created using the OSF/Motif
toolkit.
UserFont is used for text entered into windows. The following resources are set by UserFont:
*Font
—supports earlier
versions of X applications
*FontSet
—the primary
setting
*XmText*FontList
—displayed
in text entry boxes
*XmTextField*FontList
—displayed
in text entry boxes
The fonts used for each selection in the Font dialog box are specified in the /usr/dt/app-defaults/Dtstyle resource file. Up to seven sizes can be specified.
NumFonts
—number of font
sizes in the Font dialog box
SystemFont[1-7]
—up to seven resources assigning a specific
font to a Font dialog box selection for SystemFont
UserFont[1-7]
font to a Font dialog box selection for UserFont
The default fonts for these resources have been chosen for readability on various displays. If you want a specific font for an application, set the font with an application font resource rather than changing these desktop fonts.
For more information about application fonts, see the DtStdAppFontNames(5) and DtStdInterfaceFontNames(5) man pages.
Type the following:
xlsfonts [-options] [-fn pattern]
A list of XLFD names and font alias names available on your system is displayed. Bitmap fonts show values in all fourteen XLFD fields. Scalable typefaces show zeros in the PixelSize, PointSize, ResolutionX, and ResolutionY positions.
To check for specific fonts, use the pattern-matching capability of xlsfonts. Use wildcards to replace the part of the pattern you are not trying to match.
If xlsfonts does not show any font names starting with dt, your font path does not include the desktop fonts. Type the following command to include the desktop fonts into your available fonts:
xset +fp directory name
where directory name is the directory containing the desktop fonts. The default location set by session startup is /usr/dt/config/xfonts/language.
For additional information:
The xset and xlsfonts man pages list the available options.
Using the X Window System explains font alias names and the xset client.
Use the -xrm command-line option to specify a font resource for a specific client. For example:
application name -xrm \ "*bitstream-charter-medium-r-normal-8-88-75-75-p-45-iso8859-1"
A font is specified by listing fourteen different characteristics, separated by dashes (-). This is called the X Logical Font Description (XLFD). In some cases, a property in the list can be replaced by a * wildcard, and a character within a property can be replaced by a ? wildcard. Table 17–4 lists font property string specifications.
The form of the property string specification is:
"-Foundry-FamilyName-WeightName- Slant-SetwidthName-AddStyleName-PixelSize- PointSize-ResolutionX-ResolutionY-Spacing- AverageWidth-CharSetRegistry-CharSetCoding"
Table 17–4 Font Property String Specification
Property String |
Definition |
Foundry |
A string identifying the font designer |
FamilyName |
A string identifying the trademarked name of the font |
WeightName |
A string giving the relative weight of the font, such as bold |
Slant |
A code describing the direction of slant: R (Roman–no slant) I (Italic–slant right) O (Oblique–slant right) RI (Reverse Italic–slant left) RO (Reverse Oblique–slant left) |
SetwidthName |
A string describing the width, such as compressed or expanded |
AddStyleName |
A string providing any additional information needed to uniquely identify the font |
PixelSize |
An integer giving the size of an em-square in pixels |
PointSize |
An integer giving the size of an em-square in decipoints |
ResolutionX |
An integer giving the horizontal resolution in pixels |
ResolutionY |
An integer giving the vertical resolution in pixels |
Spacing |
A code specifying the spacing between units: M (Monospace--fixed pitch) P (Proportional space--variable pitch) C (Character cell) |
AverageWidth |
An integer giving the average width in 1/10th pixels |
CharSetRegistry |
A string identifying the registration authority that has registered the font encoding |
CharSetEncoding |
A string identifying the character set in the specified registry |
The following XLFD name describes a font named charter made by Bitstream that supports the ISO8859-1 standard encoding:
-bitstream-charter-medium-r-normal--8-80-75-75-p-45-iso8859-1
It is medium weight, with no special slanting, and normal width. The font is proportional, with an em-square box of 8 pixels or 8.0 points. The horizontal and vertical resolution are both 75 pixels. The average width of a character is 45 1/10ths pixels or 4.5 pixels.
Parts of this string can be replaced by wildcards. The system uses the first font it finds that matches the parts you have specified.
If all you want is an eight-pixel charter font, you could use:
*-charter-*-*-*-*-8-*
By selecting the Attributes button from the Style Manager Font dialog box, you can view the following font group attributes:
Font Group
Size
Alias
Alias XLFD
Alias Location
Font
Font XLFD
When a user adds a font group, it is stored in the following location:
HomeDirectory/.dt/sdtfonts/host/locale/typeface-nnnnnn
host is the local workstation's host name.
locale is the user's current locale such as “C” or “ja.”
typeface-nnnnnn is a name derived from the selected font and a unique generated number.
This font group directory contains the following three files
fonts.alias
fonts.dir
sdtfonts.group
The fonts.alias and fonts.dir files are the normal X11 font files suitable for adding to the Xserver's font path. The sdtfonts.group file contains the user specified font group name.
So that other users can access the font groups on a workstation, the system administrator can copy font groups to the /etc/dt/sdtfonts/locale directory or to the /usr/openwin/lib/X11/stdfonts/locale directory. Session Manager first looks in HomeDirectory/.dt/stdfonts/host/locale, next in /etc/dt/sdtfonts/locale, and last in /usr/openwin/lib/X11/stdfonts/locale.
This section describes:
How Style Manager sets display colors.
Resources used by Style Manager to control desktop color usage.
A palette consists a group of color sets. The color sets for the current palette are shown in the Style Manager Color dialog box
A file exists for each palette. The paletteDirectories resource specifies the directories containing palette files. By default, this resource contains:
Built-in palettes: /usr/dt/palettes
System-wide palettes: /etc/dt/palettes
Personal palettes: HomeDirectory/.dt/palettes
Each color set in the current palette is represented by a color button in the Style Manager Color dialog box. Each color is identified by a color set ID—a number from 1 to 8.
Each color set is composed of up to five colors. Each color button displays the background color of the color set. The five colors in each color set represent the following display component resources:
foreground—the foreground of an application window or window frame. It is always black or white. This is generally used for text within windows and titles.
background—the background of the application or the window frame.
topShadowColor—the color of the top and left bevels of application controls (such as push buttons) and window frames.
bottomShadowColor—the color of the bottom and right bevels of application controls and window frames.
selectColor—the color that indicates the active state of certain controls, such as active toggles and buttons.
The number of color sets used by each palette is determined by the colorUse resource, which the user can set using the Style Manager Number of Colors To Use dialog box.
Style Manager uses RGB values when writing color information to its palette files. The syntax for RGB numbers is:
#RedGreenBlue
Red, Green, and Blue are hexadecimal numbers, each 1 to 4 digits long, that indicate the amount of that color used. There must be the same number of digits for each of the colors. Thus, valid color values consist of 3, 6, 9, or 12 hexadecimal digits.
For example, white can be specified in any of the following ways:
#fff #ffffff #fffffffff #fffffffffffff
If you set a color resource directly, you can use either the color name or RGB value. The file /usr/lib/X11/rgb.txt lists all the named colors.
The desktop maps color sets to various display elements through resources and makes the assignments shown in Table 17–5.
Table 17–5 Mapped Color Sets to Resources
Resource |
Display element |
Application's menu bar, menus, and dialog boxes |
These resources take a color set ID as their value. Coloring display elements with color set IDs allows the element to dynamically change to the new color scheme when a new palette is selected with Style Manager.
You can use these resources for individual applications. For example, the following line shows how you would visually group all dtterm windows by using color set 8 for their primary color.
dtterm*primaryColorSetId: 8
The color set IDs used for display elements depend on the Number of Colors setting in Style Manager:
Table 17–6 shows the color set IDs for high color (8 color sets)—Style Manager setting More Colors for Desktop.
Table 17–6 High color
Color set ID |
Display element |
1 |
Active window frame color |
2 |
Inactive window frame color |
3 |
Unused (by default) |
4 |
Text entry areas |
5 |
Application's main background areas |
6 |
7 |
Unused by default |
8 |
Front Panel background |
Table 17–7 shows the color set IDs for medium color (4 color sets)—Style Manager setting More Colors for Applications.
Table 17–7 Medium color
Color set ID |
Display element |
1 |
2 |
3 |
Application and Front Panel background color |
4 |
Text entry areas |
Table 17–8 shows the color IDs for low color (2 color sets)—Style Manager setting Most Colors for Applications.
Table 17–8 Low color
Color set ID |
Display element |
1 |
Active window frame, workspace selection buttons |
2 |
All other display elements |
You can dynamically change color for desktop applications and other cooperating applications through Style Manager. The foreground and background colors set by Style Manager are available to non-cooperating applications.
For a client to respond to Style Manager color changes, the client must be using the desktop Motif library. Clients written with other toolkits cannot change color dynamically in response to Style Manager changes. Color changes for these clients do not take effect until the client is restarted.
There must be no other specific color resources applied for the client. This includes user-specified resources, application defaults, and resources built into the application.
Clients can specify primaryColorSetId and secondaryColorSetId resources to use certain colors within a desktop palette.
The number of colors used by Style Manager depends on the values for the following resources:
colorUse—configures the number of colors the desktop uses
shadowPixmaps—directs the desktop to replace the two shadow colors with pixmaps
foregroundColor—specifies if the foreground color changes dynamically
dynamicColor—controls whether applications change color when you switch palettes
Table 17–9lists the maximum number of colors allocated by the desktop.
Table 17–9 Number of Desktop Colors
Display |
Maximum Number of Colors |
Number Derived From |
B_W |
2 |
Black and white |
LOW_COLOR |
12 |
Two color sets times five colors plus black and white |
MEDIUM_COLOR |
22 |
Four color sets times five colors plus black and white |
HIGH_COLOR |
42 |
Eight color sets times five colors plus black and white |
To determine the maximum number of colors:
Multiply the number of color sets in the palette by the number of colors within each color set.
Add 2 (for black and white).
However, with the following configuration you would only have ten colors in your palette: four color sets times two colors in each set (background and selectColor) plus black and white:
*colorUse: MEDIUM_COLOR *shadowPixmaps: True *foregroundColor: White
Multi-color icons use fourteen additional colors.
The default value of the colorUse resource is MEDIUM_COLOR. The value of this resource affects the number of color sets used in a palette. Other resources affect the number of colors used to make shadows. The value of the colorUse resource also affects the use of multi-color icons.
Value |
Description |
B_W |
“Black and White” Style Manager setting Displays with 1 to 3 color planes Number of color sets: 2 Maximum number of colors: 2 Default number of colors: 2 No multicolor icons |
LOW_COLOR |
“Most Color for Applications” Style Manager setting Displays with 4 to 5 color planes Number of color sets: 2 Maximum number of colors: 12 Default number of colors: 12 No multicolor icons |
MEDIUM_COLOR |
“More Colors for Application” Style Manager setting Displays with 6 color planes Number of color sets: 4 Maximum number of colors: 22 Default number of colors: 22 Multicolor icons |
HIGH_COLOR |
“More Colors for Desktop” Style Manager setting Displays with 7 or more color planes Number of color sets: 8 Maximum number of colors: 42 Default number of colors: 42 Multicolor icons |
default |
The desktop chooses the correct value for that display. (To reduce the number of colors used by the desktop for high-color displays, the default colorUse resource is set to MEDIUM_COLOR.) |
The shadowPixmaps resource directs the desktop to replace the two shadow colors with pixmaps. These pixmaps mix the background color with black or white to simulate top or bottom shadow values. This reduces the number of needed colors by two, since color cells do not need to be allocated for the shadow colors.
Value |
Description |
True |
The desktop creates a topShadowPixmap and bottomShadowPixmap to use instead of the shadow colors. |
False |
topShadowColor and bottomShadowColor from the palette are used. |
The default value for shadowPixmaps depends on the colorUse resource you have and the hardware support for the display.
The foregroundColor resource specifies how the foreground is configured in a palette.
Setting |
Result |
White |
Foreground is set to white. |
Black |
Foreground is set to black. |
Dynamic (Default) |
Foreground is dynamically set to black or white, depending on the value of background. For instance, white letters on a yellow background are difficult to read, so the system chooses black. |
If foregroundColor is set to either Black or White, the number of colors in the color set is reduced by one, and the foreground will not change in response to changes in the background color.
The default value for foregroundColor is Dynamic, except where the value of colorUse is B_W.
The dynamicColor resource controls whether applications change color dynamically; that is, whether the clients change color when you switch palettes.
Value |
Description |
True |
Clients change color dynamically when a new palette is selected. This is the default value. |
False |
Clients do not change color dynamically. When a new palette is selected, clients will use the new colors when the session is restarted. |
When the value of the dynamicColor resource is True, clients that cannot change colors dynamically (non-Motif applications) allocate different cells in the color map than clients that can change colors dynamically, even if you see the same color.
Since all clients can share the same color cells, setting dynamicColor to False reduces the number of colors your desktop consumes.
The desktop defines a default shadow thickness of one pixel for the components in application windows, such as button shadows and focus highlight. Motif 1.2 applications use this resource value; other applications may not obtain this resource value and therefore will appear different on the display.
To set the shadow thickness to one pixel for non-Motif 1.2 applications:
Log in as root.
Create the /etc/dt/config/language/sys.resources file.
Specify the application-specific resource in /etc/dt/config/language/sys.resources as follows:
application_class_name*XmCascadeButton*shadowThickness: 1
For more information about overriding system default resources and specifying additional resources for all desktop users, see Loading the Session Resources
