System Administration Guide: IP Services
Modifying the Oracle Solaris DHCP Client's Option Information
If you add a new DHCP option to your DHCP server, you must add a complementary entry to each DHCP client's option information. If you have a DHCP client that is not a Oracle Solaris DHCP client, refer to that client's documentation for information about adding options or symbols.
On an Oracle Solaris DHCP client, you must edit the /etc/dhcp/inittab file and add an entry for each option that you add to the DHCP server. If you later modify the option on the server, you must also modify the entry in the client's /etc/dhcp/inittab file.
Refer to the dhcp_inittab(4) man page for detailed information about the syntax of the /etc/dhcp/inittab file.
Note –
If you added DHCP options to the dhcptags file in a previous Oracle Solaris release, you must add the options to the /etc/dhcp/inittab file. See DHCP Option Information for more information.
