System Administration Guide: IP Services
ProcedureHow to Modify the SPI Section
  1. Assume the Primary Administrator role, or become superuser, on the system where you want to enable Mobile IP.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. Type the following command for each label that you want to modify in the SPI section:
    # mipagentconfig change SPI SPI-identifier <label> <value>
    For example, if you are changing the key for SPI 257 to 5af2aee39ff0b332, use the following command.
    # mipagentconfig change SPI 257 Key 5af2aee39ff0b332
Example 28–5 Modifying the SPI Section
The following example shows how to change the ReplayMethod label in the configuration file's SPI section.
# mipagentconfig change SPI 257 ReplayMethod timestamps
