System Administration Guide: IP Services
ProcedureHow to Modify the Pool Section
  1. Assume the Primary Administrator role, or become superuser, on the system where you want to enable Mobile IP.
    The Primary Administrator role includes the Primary Administrator profile. To create the role and assign the role to a user, see Chapter 2, Working With the Solaris Management Console (Tasks), in System Administration Guide: Basic Administration.
  2. Type the following command for each label that you want to modify in the Pool section:
    # mipagentconfig change Pool pool-identifier <label> <value>
Example 28–4 Modifying the Pool Section
The following example shows the commands to use for changing the base address to 192.168.1.1 and the size of Pool 10 to 100.
# mipagentconfig change Pool 10 BaseAddress 192.168.1.1
# mipagentconfig change Pool 10 Size 100
