This section contains several procedures that are related to .forward file administration. Because these files can be edited by users, the files can cause problems. For more information, refer to .forward Files in Chapter 14, Mail Services (Reference).
Refer to the following:
This procedure, which prevents automated forwarding, disables the .forward file for a particular host.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
Make a copy of /etc/mail/cf/domain/solaris-generic.m4 or your site-specific domain m4 file.
# cd /etc/mail/cf/domain # cp solaris-generic.m4 mydomain.m4 |
Add the following line to the file that you just created.
define(`confFORWARD_PATH',`')dnl |
If a value for confFORWARD_PATH already exists in the m4 file, replace the value with this null value.
Build and install a new configuration file.
If you need help with this step, refer to How to Build a New sendmail.cf File.
When you edit the .mc file, remember to change DOMAIN(`solaris-generic') to DOMAIN(`mydomain').
If, for example, you want to put all .forward files in a common directory, follow these instructions.
define(`confFORWARD_PATH',`$z/.forward:/var/forward/$u')dnl |
If a value for confFORWARD_PATH already exists in the m4 file, replace the value with this new value.
This file is not included in the standard release. You must add the file if users are to be allowed to use .forward files to forward mail to a program or to a file. You can create the file manually by using grep to identify all of the shells that are listed in your password file. You can then type the shells into the file. However, the following procedure, which employs a script that can be downloaded, is easier to use.
Download the script.
To generate a list of shells, run the gen-etc-shells script.
# ./gen-etc-shells.sh > /tmp/shells |
This script uses the getent command to collect the names of shells that are included in the password file sources that are listed in /etc/nsswitch.conf.
Inspect and edit the list of shells in /tmp/shells.
With the editor of your choice, remove any shells that you are not including.
Move the file to /etc/shells.
# mv /tmp/shells /etc/shells |
