System Administration Guide: Network Services
Local Mail Only
The simplest mail configuration, as shown in Figure 13–1, is two or more workstations that are connected to one mail host. Mail is completely local. All the clients store mail on their local disks, and the clients act as mail servers. Mail addresses are parsed by using the /etc/mail/aliases files.
Figure 13–1 Local Mail Configuration
Diagram shows the dependencies of a mail host to mail
clients.
To set up this kind of mail configuration, you need the following.
For task information about setting up your mail service, refer to Setting Up Mail Services. If you are looking for a particular procedure that is related to setting up your mail service, refer to Setting Up Mail Services (Task Map).
