System Administration Guide: Network Services
Local Mail and a Remote Connection
The most common mail configuration in a small network is shown in Figure 13–2. One system includes the mail server, the mail host, and the mail gateway that provides the remote connection. Mail is distributed by using the /etc/mail/aliases files on the mail gateway. No name service is required.
Figure 13–2 Local Mail Configuration With a UUCP Connection
Diagram shows the dependencies of mail clients to a mail
gateway.
In this configuration, you can assume that the mail clients mount their mail files from /var/mail on the mail host. To set up this kind of mail configuration, you need the following.
For task information about setting up your mail service, refer to Setting Up Mail Services. If you are looking for a particular procedure that is related to setting up your mail service, refer to Setting Up Mail Services (Task Map).
