System Administration Guide: Network Services
Changing the sendmail Configuration
How to Build a New sendmail.cf File shows you how to build the configuration file. Although you can still use older versions of sendmail.cf files, the best practice is to use the new format.
For more details, refer to the following.
ProcedureHow to Build a New sendmail.cf File
The following procedure shows you how to build a new configuration file.
Note –
/usr/lib/mail/cf/main-v7sun.mc is now /etc/mail/cf/cf/sendmail.mc.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Stop sendmail.
    # svcadm disable -t network/smtp:sendmail
  3. Make a copy of the configuration files that you are changing.
    # cd /etc/mail/cf/cf
    # cp sendmail.mc myhost.mc
    myhost
    Select a new name for your .mc file.
  4. Edit the new configuration files (for example, myhost.mc), as necessary.
    For example, add the following command line to enable domain masquerading.
    # cat myhost.mc
    MASQUERADE_AS(`host.domain')
    host.domain
    Use the desired host name and domain name.
    In this example, MASQUERADE_AS causes sent mail to be labeled as originating from host.domain, rather than $j.
  5. Build the configuration file by using m4.
    # /usr/ccs/bin/make myhost.cf
  6. Test the new configuration file by using the -C option to specify the new file.
    # /usr/lib/sendmail -C myhost.cf -v testaddr </dev/null
    While this command displays messages, it sends a message to testaddr. Only outgoing mail can be tested without restarting the sendmail service on the system. For systems that are not handling mail yet, use the full testing procedure in How to Test the Mail Configuration.
  7. Install the new configuration file after making a copy of the original.
    # cp /etc/mail/sendmail.cf /etc/mail/sendmail.cf.save
    # cp myhost.cf /etc/mail/sendmail.cf
  8. Restart the sendmail service.
    # svcadm enable network/smtp:sendmail
Setting Up a Virtual Host
If you need to assign more than one IP address to a host, see this Web site: http://www.sendmail.org/tips/virtualHosting. This site provides complete instructions about how to use sendmail to set up a virtual host. However, in the “Sendmail Configuration” section, do not perform step 3b, as shown in the following.
# cd sendmail-VERSION/cf/cf
# ./Build mailserver.cf
# cp mailserver.cf /etc/mail/sendmail.cf
Instead, for the Solaris operating system, perform the following steps.
# /usr/ccs/bin/make mailserver.cf
mailserver
Use the name of the .cf file.
Changing the sendmail Configuration outlines the same three steps as part of the build process.
After you have generated your /etc/mail/sendmail.cf file, you can continue with the next steps to create a virtual user table.
ProcedureHow to Automatically Rebuild a Configuration File
If you have built your own copy of sendmail.cf or submit.cf, the configuration file is not replaced during the upgrade process. The following procedure shows how to configure the sendmail service properties so that the sendmail.cf file is automatically rebuilt for you. For instructions on how to automatically build the submit.cf configuration file, see Example 13–1. You may combine these procedures if you need to build both files.
  2. Set the sendmail properties.
    # svccfg -s sendmail
    svc:/network/smtp:sendmail> setprop config/path_to_sendmail_mc=/etc/mail/cf/cf/myhost.mc
    svc:/network/smtp:sendmail> quit
  3. Refresh and restart the sendmail service.
    The first command pushes the changes into the running snapshot. The second command restarts the sendmail service using the new options.
    # svcadm refresh svc:/network/smtp:sendmail
    # svcadm restart svc:/network/smtp:sendmail
Example 13–1 Establishing Automatic Rebuilding of submit.cf
This procedure configures the sendmail service, such that the submit.mc configuration file is rebuilt automatically.
# svccfg -s sendmail-client:default
svc:/network/smtp:sendmail> setprop config/path_to_submit_mc=/etc/mail/cf/cf/submit-myhost.mc
svc:/network/smtp:sendmail> exit
# svcadm refresh svc:/network/sendmail-client
# svcadm restart svc:/network/sendmail-client
ProcedureHow to Use sendmail in the Open Mode
In the Solaris 10 release, the sendmail service was changed so that it would run in local–only mode by default. The local-only mode means that only mail from the local host is accepted. Messages from any other systems are rejected. Earlier Solaris releases were configured to accept incoming mail from all remote systems, which is known as the open mode. To use the open mode, use the following procedure.
Caution – Caution –
Running sendmail in the local–only mode is much more secure than running in the open mode. Make sure that you are aware of the potential security risks if you follow this procedure.
    svc:/network/smtp:sendmail> setprop config/local_only = false
ProcedureHow to Set SMTP to Use TLS
Starting in the Solaris 10 1/06 release, SMTP can use Transport Layer Security (TLS) in version 8.13 of sendmail. This service to SMTP servers and clients provides private, authenticated communications over the Internet, as well as protection from eavesdroppers and attackers. Note that this service is not enabled by default.
The following procedure uses sample data to show you how to set up the certificates that enable sendmail to use TLS. For more information, see Support for Running SMTP With TLS in Version 8.13 of sendmail.
  2. Stop sendmail.
  3. Set up the certificates that enable sendmail to use TLS.
    1. Complete the following:
      # cd /etc/mail
      # mkdir -p certs/CA
      # cd certs/CA
      # mkdir certs crl newcerts private
      # echo "01" > serial
      # cp /dev/null index.txt
      # cp /etc/sfw/openssl/openssl.cnf .
    2. Use your preferred text editor to change the dir value in the openssl.cnf file from /etc/sfw/openssl to /etc/mail/certs/CA.
    3. Use the openssl command-line tool to implement TLS.
      Note that the following command line generates interactive text.
      # openssl req -new -x509 -keyout private/cakey.pem -out cacert.pem -days 365 \
      -config openssl.cnf
      Generating a 1024 bit RSA private key
      writing new private key to 'private/cakey.pem'
      Enter PEM pass phrase:
      Verifying - Enter PEM pass phrase:
      You are about to be asked to enter information that will be incorporated
      into your certificate request.
      What you are about to enter is what is called a Distinguished Name or a DN.
      There are quite a few fields but you can leave some blank
      For some fields there will be a default value,
      If you enter '.', the field will be left blank.
      Country Name (2 letter code) []:US
      State or Province Name (full name) []:California
      Locality Name (eg, city) []:Menlo Park
      Organization Name (eg, company) [Unconfigured OpenSSL Installation]:Sun Microsystems
      Organizational Unit Name (eg, section) []:Solaris
      Common Name (eg, YOUR name) []:somehost.somedomain.example.com
      Email Address []:someuser@example.com
      req
      This command creates and processes certificate requests.
      -new
      This req option generates a new certificate request.
      -x509
      This req option creates a self-signed certificate.
      This req option enables you to assign private/cakey.pem as the file name for your newly created private key.
      -out cacert.pem
      This req option enables you to assign cacert.pem as your output file.
      -days 365
      This req option enables you to certify the certificate for 365 days. The default value is 30.
      -config openssl.cnf
      This req option enables you to specify openssl.cnf as the configuration file.
      Note that this command requires that you provide the following:
      • Country Name, such as US.
      • State or Province Name, such as California.
      • Locality Name, such as Menlo Park.
      • Organization Name, such as Sun Microsystems.
      • Organizational Unit Name, such as Solaris.
      • Common Name, which is the machine's fully qualified host name. For more information, see the check-hostname(1M) man page.
      • Email Address, such as someuser@example.com.
  4. (Optional) If you need a new secure connection, make a new certificate and sign the new certificate with the certificate authority.
    1. Make a new certificate.
      # cd /etc/mail/certs/CA
      # openssl req -nodes -new -x509 -keyout newreq.pem -out newreq.pem -days 365 \
      -config openssl.cnf
      writing new private key to 'newreq.pem'
      This command requires that you provide the same information that you provided in step 3c.
      Note that in this example, the certificate and private key are in the file newreq.pem.
    2. Sign the new certificate with the certificate authority.
      # openssl x509 -x509toreq -in newreq.pem -signkey newreq.pem -out tmp.pem
      Getting request Private Key
      Generating certificate request
      # openssl ca -config openssl.cnf -policy policy_anything -out newcert.pem -infiles tmp.pem
      Using configuration from openssl.cnf
      Enter pass phrase for /etc/mail/certs/CA/private/cakey.pem:
      Check that the request matches the signature
      Signature ok
      Certificate Details:
              Serial Number: 1 (0x1)
              Validity
                  Not Before: Jun 23 18:44:38 2005 GMT
                  Not After : Jun 23 18:44:38 2006 GMT
              Subject:
                  countryName               = US
                  stateOrProvinceName       = California
                  localityName              = Menlo Park
                  organizationName          = Sun Microsystems
                  organizationalUnitName    = Solaris
                  commonName                = somehost.somedomain.example.com
                  emailAddress              = someuser@example.com
              X509v3 extensions:
                  X509v3 Basic Constraints:
                      CA:FALSE
                  Netscape Comment:
                      OpenSSL Generated Certificate
                  X509v3 Subject Key Identifier:
                      93:D4:1F:C3:36:50:C5:97:D7:5E:01:E4:E3:4B:5D:0B:1F:96:9C:E2
                  X509v3 Authority Key Identifier:
                      keyid:99:47:F7:17:CF:52:2A:74:A2:C0:13:38:20:6B:F1:B3:89:84:CC:68
                      DirName:/C=US/ST=California/L=Menlo Park/O=Sun Microsystems/OU=Solaris/\
                      CN=someuser@example.com/emailAddress=someuser@example.com
                      serial:00
      Certificate is to be certified until Jun 23 18:44:38 2006 GMT (365 days)
      Sign the certificate? [y/n]:y
      1 out of 1 certificate requests certified, commit? [y/n]y
      Write out database with 1 new entries
      Data Base Updated
      # rm -f tmp.pem
      In this example the file newreq.pem contains the unsigned certificate and private key. The file newcert.pem contains the signed certificate.
      x509 utility
      Displays certificate information, converts certificates to various forms, and signs certificate requests
      ca application
      Used to sign certificate requests in a variety of forms and to generate CRLs (certificate revocation lists)
  5. Enable sendmail to use the certificates by adding the following lines to your .mc file.
    define(`confCACERT_PATH', `/etc/mail/certs')dnl
    define(`confCACERT', `/etc/mail/certs/CAcert.pem')dnl
    define(`confSERVER_CERT', `/etc/mail/certs/MYcert.pem')dnl
    define(`confSERVER_KEY', `/etc/mail/certs/MYkey.pem')dnl
    define(`confCLIENT_CERT', `/etc/mail/certs/MYcert.pem')dnl
    define(`confCLIENT_KEY', `/etc/mail/certs/MYkey.pem')dnl
    For more information, see Configuration File Options for Running SMTP With TLS.
  6. Rebuild and install your sendmail.cf file in your /etc/mail directory.
    For detailed instructions, see Changing the sendmail Configuration.
  7. Create symbolic links from the files you created with openssl to the files you defined in your .mc file.
    # ln -s CA/cacert.pem CAcert.pem
    # ln -s CA/newcert.pem MYcert.pem
    # ln -s CA/newreq.pem MYkey.pem
  8. For added security, deny read permission to group and others for MYkey.pem.
    # chmod go-r MYkey.pem
  9. Use a symbolic link to install CA certs in the directory assigned to confCACERT_PATH.
    # C=CAcert.pem
    # ln -s $C `openssl x509 -noout -hash < $C`.0
  10. For secure mail with other hosts, install their host certificates.
    1. Copy the file defined by the other host's confCACERT option to /etc/mail/certs/host.domain.cert.pem.
      Replace host.domain with the other host's fully qualified host name.
    2. Use a symbolic link to install CA certs in the directory assigned to confCACERT_PATH.
      # C=host.domain.cert.pem
  11. Restart sendmail.
Example 13–2 Received: Mail Header
The following is an example of a Received: header for secure mail with TLS.
Received: from his.example.com ([IPv6:2001:db8:3c4d:15::1a2f:1a2b])
        by her.example.com (8.13.4+Sun/8.13.4) with ESMTP id j2TNUB8i242496
        (version=TLSv1/SSLv3 cipher=DHE-RSA-AES256-SHA bits=256 verify=OK)
        for <janepc@her.example.com>; Tue, 29 Mar 2005 15:30:11 -0800 (PST)
Received: from her.example.com (her.city.example.com [192.168.0.0])
        by his.example.com (8.13.4+Sun/8.13.4) with ESMTP id j2TNU7cl571102
        for <janepc@her.example.com>; Tue, 29 Mar 2005 15:30:07 -0800 (PST)
Note that the value for verify is OK, which means that the authentication was successful. For more information, see Macros for Running SMTP With TLS.
See Also
The following OpenSSL man pages:
ProcedureHow to Manage Mail Delivery by Using an Alternate Configuration of sendmail.cf
To facilitate the transport of inbound mail and outbound mail, the new default configuration of sendmail uses a daemon and a client queue runner. The client queue runner must be able to submit mail to the daemon on the local SMTP port. If the daemon is not listening on the SMTP port, the mail remains in the queue. To avoid this problem, perform the following task. For more information about the daemon and client queue runner and to understand why you might have to use this alternate configuration, refer to submit.cf Configuration File From Version 8.12 of sendmail.
This procedure ensures that your daemon runs only to accept connections from the local host.
  2. Stop sendmail client service.
    # svcadm disable -t sendmail-client
  3. Make a copy of the configuration file that you are changing.
    # cp submit.mc submit-myhost.mc
    myhost
  4. Edit the new configuration file (for example, submit-myhost.mc)
    Change the listening host IP address to the msp definition.
    # grep msp submit-myhost.mc
    FEATURE(`msp', `[#.#.#.#]')dnl
    # /usr/ccs/bin/make submit-myhost.cf
  6. Install the new configuration file after making a copy of the original.
    # cp /etc/mail/submit.cf /etc/mail/submit.cf.save
    # cp submit-myhost.cf /etc/mail/submit.cf
  7. Restart the sendmail client service.
    # svcadm enable sendmail-client
