System Administration Guide: Network Services
Additional Macros From Version 8.12 of sendmail
In this section, you can find a table that describes the additional macros that are used to build the sendmail configuration file.
Table 14–22 Additional Macros Used to Build the sendmail Configuration File
Macro
Description
LOCAL_MAILER_EOL
Overrides the default end-of-line string for the local mailer.
LOCAL_MAILER_FLAGS
Adds Return-Path: header by default.
MAIL_SETTINGS_DIR
Contains the path (including the trailing slash) for the mail settings directory.
MODIFY_MAILER_FLAGS
Improves the *_MAILER_FLAGS. This macro sets, adds, or deletes flags.
RELAY_MAILER_FLAGS
Defines additional flags for the relay mailer.
