System Administration Guide: Network Services
Additional MAX Macros From Version 8.12 of sendmail
Use the following macros to configure the maximum number of commands that can be received before sendmail slows its delivery. You can set these MAX macros at compile time. The maximum values in the following table also represent the current default values.
Table 14–23 Additional MAX Macros
Macro
Maximum Value
Commands Checked by Each Macro
MAXBADCOMMANDS
25
Unknown commands
MAXNOOPCOMMANDS
20
NOOP, VERB, ONEX, XUSR
MAXHELOCOMMANDS
HELO, EHLO
MAXVRFYCOMMANDS
VRFY, EXPN
MAXETRNCOMMANDS
ETRN
Note –
You can disable a macro's check by setting the macro's value to zero.
