System Administration Guide: Network Services
Interpositioning Library for Daemon Support of the Door Server
Many web servers use AF_INET sockets. By default, NCA uses AF_NCA sockets. To correct this situation, an interpositioning library is provided. The new library is loaded in front of the standard socket library, The library call bind() is interposed by the new library, Suppose that the status is enabled in /etc/nca/ncakmod.conf. The version of Apache that is included with the Solaris 9 and Solaris 10 release is already set up to call this library. If you are using IWS or Netscape servers, see How to Load the Socket Utility Library for NCA to use the new library.
